Go to Post first robotics is a ten - Hiteak [more]
Unread 15-05-2010, 16:24
Lee Reid 3136's Avatar
Lee Reid 3136 Lee Reid 3136 is offline
Part time Zombie
AKA: Captain America
FRC #3136 (Official Robot Constructors of America (ORCA))
Team Role: Human Player
Lee Reid 3136 is a glorious beacon of lightLee Reid 3136 is a glorious beacon of lightLee Reid 3136 is a glorious beacon of lightLee Reid 3136 is a glorious beacon of lightLee Reid 3136 is a glorious beacon of light
On the Platform for three points.
I think that having robot the platform during a game of Breakaway should have been worth three points and I have more justification for it then "It would have made my team win that match."
As we all know a suspend robot is one robot hanging off of another robot that is also hanging from the tower. This is worth three points. It also requires two well designed robots, robots designed to go above the normal call of the game, two skilled drivers, and maybe some luck. It nets your alliance 5 points.
Getting a robot on to the platform also requires two well designed robots, also designed to go beyond the normal call of the game, two skilled drivers, and maybe some luck and yet it nets your alliance only 2 points.
Both getting a suspended robot and having a robot on the platform are amazing feats and I think they should be awarded more equally.
2010 VA regional: Highest seeded rookie~3rd
2010 VA regional: Judges award
Thinks to remember: 1)Ethernet cable goes in cRio port #1 2)Cloth goes all the way around bumpers 3) Don't let Ed use the good miter box, because he will make it the bad miter box 4) Don't let Joseph use the hand drill 5) Don't let Jesse play soccer inside 6) Ed is the campion 7) We don't go full speed over the bump 8) I need to grow a beard so I can stroke it thoughtfully.
Unread 15-05-2010, 18:38
Chris is me's Avatar
AKA: Pinecone
Re: On the Platform for three points.
Let me spin this the other way. Isn't the fact that the challenge was only worth two points a sign that such a design endeavor wasn't worth it? FIRST has game objectives every year that are generally "not worth it" (like suspension), perhaps teams that built ramps did a poor job of identifying what was worth the risk and reward.
Unread 15-05-2010, 22:39
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Chris, that suggests that absolutely any point values are fine, because teams will adjust accordingly. What is being suggested is that there would be a more balanced/diverse/enjoyable game if point values were different.
I don't absolutely agree with the pros, but here's a problem for you. If you say 'platform elevation' is touching the platform but not the tower bars, then it's way too hard to line up. If you say touching platform and/or bars, teams hanging primarily on the bar can just release fabric or something similar onto the platform and get extra points.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 15-05-2010, 23:54
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm trying to understand what you're getting at here, but I can't get past your statement that getting a robot onto the platform requires 2 robots to earn 2 points.
If it requires 2 robots to earn 2 points, yet 2 robots can get 4 points if they both hang, why would you ever attempt the former?
2001-2004: Team 100
2006-Present: Team 254
Unread 15-05-2010, 23:57
Brandon Holley's Avatar
Building off of this, it doesn't necessarily require 2 robots to get onto the platform either, which eliminates the bonus you are suggesting for a collaboration of sorts between teams to get onto the platform
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 16-05-2010, 19:31
DivisionDragons DivisionDragons is offline
FRC #1606
DivisionDragons is an unknown quantity at this point
So its a 3 robot team, one has no suspension system, one has the ramp but no suspension system, and the other can hang. If the 2nd robot were to deploy the ramp and let the 1st robot climb onto the tower, and the 3rd robot were to hang, then you would get 4 bonus points.
However, if the 2nd robot DID NOT have a ramp, the 1st robot has no way of getting onto the platform, therefore the team would only get 2 points from the 3rd robot hanging.
The problem with your idea is that you are assuming all 3 robots can hang, and that is not the case in most instances.
Unread 16-05-2010, 19:34
AKA: Pinecone
Maybe they should be...
Regardless of that, why build a robot that depends on your opponent to get two points when you could elevate yourself for 2 points? Teams that built ramps chose their design poorly, in my opinion.
Unread 16-05-2010, 20:12
NickE's Avatar
NickE NickE is offline
_
There are multiple ways to get on the platform. In theory, a robot could be built to drive onto the platform from the bump. For most teams, this was probably harder than simply hanging, so they chose to hang instead.
Unread 16-05-2010, 20:16
Cory's Avatar
AKA: Cory McBride
How many teams had ramps that consistently allowed their partners to get on the platform?
Not very many from what I saw.
2001-2004: Team 100
Unread 16-05-2010, 20:51
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
well, any vertical pole hanger that touches the platform to keep it from sliding below 18" would technically be on the platform. so, here are the teams that i can think of that would get 3 points:
33
1625
135
1114
and MANY more!
so it is not as exclusive as one would think.
Unread 16-05-2010, 21:00
AKA: Pinecone
33
1625
135
1114
and MANY more!
33 and 1114 both use friction to stay above the platform, they don't actually touch it.
Unread 16-05-2010, 23:46
330 has long had a desire to be able to win a match regardless of partners' ability. If a strategy relies completely on partners, they just won't do that as their primary strategy. Building a ramp to the platform relies on partners that can climb it. Being a climber relies on partners with ramps that you can climb.
Too hard to pull off reliably to be viable. Make it 10 points, and we'll talk.
Unread 17-05-2010, 08:06
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Yep, we use friction. now if there was another bonus point for touching the platform, I think we could arrange a touch.
Unread 17-05-2010, 21:52
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
To be honest, at the beginning of the season, I woulds have liked to see more of an incentive for hanging, say 3 points on your own and 4 for hanging off of a teammate (and I partially still do), but things worked out okay. Just getting points for getting on the platform? I don't know about that... sounds like rewarding extra points for a simpler and an easier solution (say, the ramp).
Seriously, can anyone with a robot that can hang say that their hanging mechanism was easy to build?
Unread 17-05-2010, 21:55
TEE's Avatar
TEE TEE is offline
FRC #0201
And Lee, did your team try building a hanging mechanism?
Did anyone go for the Platform? Rizner General Forum 16 10-03-2010 14:16
Programs for the new FRC platform frcchile Programming 20 01-01-2009 14:29
Three cheers for Dean Kamen and the Segway Wayne Doenges Chit-Chat 10 09-05-2008 20:30
CAD software for pocket pc platform AdamHeard CAD 1 29-11-2007 22:18
Createing a platform for bonus points... GMKlenklen Technical Discussion 12 12-01-2007 16:17
