Re: VEX controller
I've always wanted to do this and wanted to repair our 2009 robot with this controller.
Questions: -Do you use male to male cables? -What do you program it in, EasyC? -Do you power the controller with the battery or the power pack that comes with it? -Is there anything else needed to run it? Thanks, -RC |
Re: VEX controller
We use EasyC and normally just run the standard tank drive code. When we use the vex controller, we're normally just trying to see how easy a mechanism is to control (ex: how easy it is to grab a ball or how well we can hold on to a ball). We run power for the Vex controller from the battery pack, NOT the 12V battery you would usually use to power your robot. Other than that, I don't think there is anything else you need. |
Re: VEX controller
I ran our 09 robot on RobotC on a VEX controller with success.
Re: VEX controller
We've used a voltage regulator to run the Vex controller from the 12v battery...I think we used a 7808 (8 volt) regulator, worked fine. Mounted on a heat sink.
The controller has a LM2940CS-5.0 (5 volt) regulator inside it, so it might get a bit warm if you run it from the 12v supply. |
Re: VEX controller
You should also be able to use the Serial<>CAN adapter.
The VEX controller has two serial ports: the Rx/Tx port and the programming port. |
| VEX radio controller | Greg Needel | FIRST Tech Challenge | 3 | 06-05-2007 15:09 |
| Wired VEX Controller | Zoheb N | VEX | 3 | 25-02-2007 13:25 |
| Vex Controller Issues | spsteam1512 | VEX | 6 | 19-02-2007 16:56 |
| IR on the Vex controller? | jgarbers | FIRST Tech Challenge | 0 | 18-04-2006 14:07 |
| Programming VEX Controller | HRobotics | Programming | 4 | 21-03-2006 23:25 |
