Go to Post You can never go wrong by gaining height by way of a Segway. - Elgin Clock [more]
Unread 15-05-2010, 21:57
Bobert's Avatar
Bobert Bobert is offline
FRC #0696
Bobert will become famous soon enoughBobert will become famous soon enough
VEX controller
Does anyone know if it is possible to use the VEX controller to control the robot? We would just hook it up directly to the Jaguars. Are the systems compatible? We are trying to simply are control system by getting rid of the Classmate and router in order to just use the VEX R/C controller. I understand that this will bypass the cRIO and all of our code. We just need to drive motors to move.
Unread 15-05-2010, 22:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: VEX controller
It works with Victor speed controllers, not sure about Jags though...the PWM signal isn't quite the same.
Unread 15-05-2010, 22:55
Re: VEX controller
The Jaguar by default uses a longer PWM pulse then the IFI control system or the VEX controller puts out. This means that it will work, but the fastest a motor would go is 2/3 speed.
You can calibrate the PWM input on the Jaguar so that it will operate at full speed with IFI control system. See the Jaguar Getting Started Guide from http://www.luminarymicro.com/jaguar
Be sure to calibrate it again when you go back to the cRIO.
Unread 15-05-2010, 23:17
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: VEX controller
Yes, you can use a Vex controller with jaguars. We do this quite a bit to test prototypes (on and off of a moving robot) and to control robots to play with and against our practice robot.
Team 1538 / The Holy Cows, 2005-2016
Unread 16-05-2010, 00:23
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: VEX controller
I've always wanted to do this and wanted to repair our 2009 robot with this controller.
Questions:
-Do you use male to male cables?
-What do you program it in, EasyC?
-Do you power the controller with the battery or the power pack that comes with it?
-Is there anything else needed to run it?
Thanks,
-RC
R.C.
MadTown Robotics Team 1323
Unread 16-05-2010, 00:47
Jon Jack's Avatar
VEX Robotics
no team (No Team)
Re: VEX controller
Questions:
Thanks,
-RC
Yes you use Male to Male cables. We usually splice some old PWM cables.
We use EasyC and normally just run the standard tank drive code. When we use the vex controller, we're normally just trying to see how easy a mechanism is to control (ex: how easy it is to grab a ball or how well we can hold on to a ball).
We run power for the Vex controller from the battery pack, NOT the 12V battery you would usually use to power your robot.
Other than that, I don't think there is anything else you need.
Unread 16-05-2010, 02:19
NickE's Avatar
NickE NickE is offline
_
Re: VEX controller
I ran our 09 robot on RobotC on a VEX controller with success.
Unread 16-05-2010, 02:47
MrForbes's Avatar
AKA: Jim
Re: VEX controller
We've used a voltage regulator to run the Vex controller from the 12v battery...I think we used a 7808 (8 volt) regulator, worked fine. Mounted on a heat sink.
The controller has a LM2940CS-5.0 (5 volt) regulator inside it, so it might get a bit warm if you run it from the 12v supply.
Unread 16-05-2010, 04:18
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: VEX controller
You should also be able to use the Serial<>CAN adapter.
The VEX controller has two serial ports: the Rx/Tx port and the programming port.
Art Dutra IV
世上无难事,只怕有心人.
VEX radio controller Greg Needel FIRST Tech Challenge 3 06-05-2007 15:09
Wired VEX Controller Zoheb N VEX 3 25-02-2007 13:25
Vex Controller Issues spsteam1512 VEX 6 19-02-2007 16:56
IR on the Vex controller? jgarbers FIRST Tech Challenge 0 18-04-2006 14:07
Programming VEX Controller HRobotics Programming 4 21-03-2006 23:25
