#8
Re: VEX controller
We've used a voltage regulator to run the Vex controller from the 12v battery...I think we used a 7808 (8 volt) regulator, worked fine. Mounted on a heat sink.
The controller has a LM2940CS-5.0 (5 volt) regulator inside it, so it might get a bit warm if you run it from the 12v supply. |
| VEX radio controller | Greg Needel | FIRST Tech Challenge | 3 | 06-05-2007 15:09 |
| Wired VEX Controller | Zoheb N | VEX | 3 | 25-02-2007 13:25 |
| Vex Controller Issues | spsteam1512 | VEX | 6 | 19-02-2007 16:56 |
| IR on the Vex controller? | jgarbers | FIRST Tech Challenge | 0 | 18-04-2006 14:07 |
| Programming VEX Controller | HRobotics | Programming | 4 | 21-03-2006 23:25 |
