Go to Post What isn't fun about watching a robot hang tubes? I love watching my team do it! - Michael Corsetto [more]
Unread 16-05-2010, 03:23
Ryutso Ryutso is offline
Modularity, modularity, modularity
AKA: Toby Cubbin
FRC #0108 (Sigmac@ts)
Ryutso is an unknown quantity at this point
CIM motor + Electrical outlet = ?
I just wanted to know if the CIM motor could be hooked to the wall outlet natively or if something could be rigged to run the CIM motor from a regular 120V AC 20A household electrical outlet?
I'm planning to invest in some CIMs for a home made project.
Unread 16-05-2010, 04:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: CIM motor + Electrical outlet = ?
No!
And a power supply to provide 12v DC at enough current to do something useful with the motors, will be kind of expensive.
When you ask a question like this, it helps to provide a lot more info about what exactly you want to do, so others here can help you figure out some other possible ways to do it.....
Unread 16-05-2010, 04:08
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
A CIM motor is rated for 12V DC (direct current). Electrical mains voltage is 60Hz 120V AC (alternating current).
To run a 12V DC motor off of 120V AC mains, you'd need an electrical transformer/power supply to both convert alternating current to direct current and to step down the voltage from 120V to 12V.
The stall current of a single CIM motor is 133 amps at 12v, which means it's using 1596 Watts of electrical power (but at this point is outputting zero watts of useful mechanical power, at the expense of becoming an excellent space heater). This means the power supply you choose to run the CIM motor must be capable of sinking at least 1596 Watts of output power. Buying a 120VAC->12VDC power supply capable of outputting at least 1596W will put a several hundred dollar dent into your wallet.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-05-2010, 04:36
Chris is me's Avatar
AKA: Pinecone
Can't you put an circuit breaker in between the DC converter and the CIM?
Unread 16-05-2010, 09:19
No, but you could use a battery from a car, motorcycle, lawn tractor, golf cart, or boat. Or you could visit several HVAC shops in your area and ask if they would allow you to salvage blower motors from some junk furnaces. They run on house current.
Unread 16-05-2010, 11:44
AdamHeard's Avatar
Lead Mentor
I don't follow what the point of that would be.
Unread 16-05-2010, 12:04
AKA: Pinecone
If the circuit breaks at 40 amps, you wouldn't need a AC-DC converter that could output 1600 watts.
Unread 16-05-2010, 12:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I have run a CIM from a high quality 500W computer power supply. You need to look at the specs though, as most computer power supplies provide more current on the 5V side than on the 12V side.
Unread 16-05-2010, 12:50
AKA: Toby Cubbin
Well what I planned to do was use 4 similar motors to drive a winch of sorts, that would lift my LCD TV up and down a stationary pole that I have in my room.
I asked around and found that the CIM's would lift the appropriate 25 pounds that my TV and 4 CIM's weigh. The only problem is, I don't want to have a car battery sitting at the foot of my bed.
Is there another electric motor that I can cluster together to lift the 20 pounds of my TV and 3 others of itself just running from 120V AC current?
EDIT: I also plan to control them with DPDT switches and would like to know if this (http://www.radioshack.com/product/index.jsp?productId=2062516&numProdsPerPage=60&y=1 0&x=13&retainProdsInSession=1) is the right switch for the job.
EDIT2: I also plan to wrap the whole controller in a project box so I'll need some tips on soldering the wire to a power cord.
Unread 16-05-2010, 13:09
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
how are you attaching this TV to the pole and what kind of pole is it?
Also, is this worth the cost of 4 of any decent motors? why not use pulleys and a cleat from a flagpole?
EDIT:to solder a wire to a power cord it might be best to put some type of breaker/ fuse block in between
Unread 16-05-2010, 13:13
AKA: Toby Cubbin
Steel pole and I was thinking of designing something like the pole locking mechanisms from this years game, only instead of being one pneumatics, it's just permanent.
Cause it'd be cooler to use motors to move it up and down the pole.
Unread 16-05-2010, 13:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
CIM peak power = 321 W
321W * 4 = 1284 W
Assuming gearbox efficiency of something extremely conservative like .5
1284W*.5 = 642W
25 lbs * 10 ft (tallest most bedroom ceilings would be) = 339 joules
Power = Work /Time
Time = Work / Power
339 Joules / 642 W = .53 seconds
This means that at half of peak power 4 CIMS will lift a TV of 0 height from your floor to your ceiling in .53 seconds. I guess my point is, how did you decide you needed 4 CIMs for this job?
Unread 16-05-2010, 14:12
AKA: Toby Cubbin
321W * 4 = 1284 W
1284W*.5 = 642W
25 lbs * 10 ft (tallest most bedroom ceilings would be) = 271.16 joules
Power = Work /Time
Time = Work / Power
271.16 Joules / 642 W = .42 seconds
This means that at half of peak power 4 CIMS will lift a TV of 0 height from your floor to your roof in .42 seconds. I guess my point is, how did you decide you needed 4 CIMs for this job?
Oh sorry. It's not 4 CIMs doing all the lifting. I'm going to arrange them diagonally like:
around a rubber ball so that I can move it up and down, but also swing it around the pole to differ in direction. So something like this:
Bold Red means it's powered:
Moves up
Moves down
Moves right
Moves left
Unread 16-05-2010, 15:07
250 ft-lb = 339 joules
Unread 16-05-2010, 15:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Oops
I used 8 ft, then thought it would be better to use 10 and apparently didn't go back and fix the math.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
CIM motor gearbox tseres Motors 3 22-05-2007 22:31
CIM motor on 30A jason701802 Motors 4 05-02-2007 20:23
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
CIM motor components natis Motors 4 13-01-2006 11:04
