Go to Post Now the real question is where are corn dogs located on that list? That is truly all that matters. - Thad House [more]
Unread 16-05-2010, 11:40
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Re: Robot Base
I got an idea to build my base but I have some questions.
How do I put a wheel directly to the gearbox(KoP gearbox).
And how do I put a wheel that is assembled just on one side of a screw?
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 16-05-2010, 11:52
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Re: Robot Base
To my knowledge you can't, not without buying hex shafts and bearings (not cheap) and basically ditching the kit chassis. also the gear reduction would be WAY to low. I think there is typically something in the range of a 3:1 reduction done with sprockets after the gearbox usually.
With a screw, again it is challenging. The kit bot just isn't made to do this. Someone who has actually done this should elaborate on this not me.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 16-05-2010, 12:06
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: Robot Base
I saw many robot with it and I want to know what shaft or hex I need.
Unread 16-05-2010, 12:21
Edoc'sil's Avatar
FRC #2531
Re: Robot Base
I really really like these
http://www.andymark.biz/am-0114.html
you assemble them with these shafts and bearings
http://www.andymark.biz/am-0520.html
http://www.andymark.biz/am-0279.html
each box takes 2 bearings and with a 4 inch wheel can be direct driven and shift on the fly from high to low gear with pneumatics.
Unread 16-05-2010, 12:32
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Re: Robot Base
You can put THIS on each wheel and then with a machine key you can put the wheels directly on the output shaft of the toughbox.
The problem is that in most cases you need support on the other side of the shaft in order that it won't get bend, so it will be wiser to get a longer shaft and put a bearing on the end of it, with the bearing inside the chassis and supported.
If you decide to go with hex shaft the you need hex bearing to the end, but not hex bearing on the wheel since you don't really need bearings on the wheels because they are direct driven and putting a bearing will lose it's point so THIS will work with a hex shaft.
If you need further help you can contact me in mail ygutman1@gmail.com, i am also from Israel so i probably will be able to help me more then some posts in here...
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 16-05-2010, 12:39
Edoc'sil's Avatar
FRC #2531
Re: Robot Base
Ya, forgot to mention insert for the wheel itself. I would suggest staying away from key ways, they sheer occasionally.
Unread 16-05-2010, 13:23
gyaniv's Avatar
AKA: Gutman Yaniv
Re: Robot Base
I've been using key ways for 2 years now and my team have been using them for 4 years (since the team was founded) and we never had any problem with them, so i don't using them. But it is his choice to make since it is his bot. there are much more methods then hex or key... Those are just the two that andymark sells...
Unread 16-05-2010, 13:31
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Robot Base
our team has always used keys, we never shear them, but we loose them, all the time. however we dont want to buy a hex broaching kit. if possible use a hex broach, but keys work just as well. something i would look at is staying away from gearboxes all together, jester-drive uses only belts to gain gear reduction. picture here. http://www.chiefdelphi.com/media/img...09401a44_l.jpg
Unread 16-05-2010, 13:36
Edoc'sil's Avatar
FRC #2531
Re: Robot Base
When we stalled a motor, (electrical hooked them up backwards) we sheared a key, We also have had issues with losing keys, they are tiny little things....
What other methods are there? Friction mounts really aren't viable due to costs/vs reliability, and they are really more used to couple shafts.
Also we never have had to broach anything while using hex shafts, we just use the bearings and andymark mounts. Because they are circular anyone with a mill can easily mount them to a bot.
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: 2Train Robot take home base Rich Wong Extra Discussion 8 31-07-2007 10:22
pic: RoboDawgs Team 288 Base & Sides of Robot # 2 drhall Robot Showcase 3 14-02-2007 12:18
pic: 932 Robot base Caleb A. Robot Showcase 5 07-02-2006 21:39
#d model of the robot base Damelvin 3D Animation and Competition 2 10-02-2005 18:50
