Re: pic: WCD Sheet Metal Concept Chassis
How would you tension the chains? Will you just CAD them to be the right distance apart?
I have a question in general about the WCD system, are you using generic bearings/bushings int he sheet metal for the axles, or are there some special ones?
Garrett, it looks awesome. ![]() Last edited by Rion Atkinson : 05-16-2010 at 02:19 PM. Reason: reodered quotes |
I have a few reasons for going with the rear direct drive. -I wanted to start off with a good majority of weight behind the middle wheels in order to reduce the amount of rock the chassis experiences while driving. -I also wanted the maximum amount of open mounting space for electronics without the gearboxes getting in the way. -With this design I'm able to put the battery closer to the center of the chassis, which helps a lot in balancing things out, and since the battery weighs more than the shifters, its placement on the chassis is more critical (at least in my opinion). -And of course... because it looks cooler Quote:
is more than enough distance from the chain to the rail, and my chain tensioner (coming soon) will help hold the chain away from the rail itself just for added protection. Thanks for the advice though ![]() Quote:
Though most teams make their own bearing blocks for their chassis, team221 sells them, and yes the hex bearings I used are AM's. |
I like this drivetrain... reminds me a lot of Vex. Now for my design questions... I have no experience, so these comments are worthless. Would it make sense to add some fillets to the triangular cutouts in the sheet? What if you had the inner flange bend in toward the chassis, so you could rivet the belly pan to it? This would also increase the serviceability of the drivetrain by giving you more access to the chain. Last edited by Chris is me : 05-17-2010 at 05:48 AM. |
As for the CAD render: if the side rails are open on the bottom for chain accessibility, are there supports on the inside of the rail to keep it from buckling in on itself? The channel shown in the reflection of the render makes be believe the side rails are very prone to torsion. I also like the rear-wheel drive; Drop-center drive train designs are TOO easily turned if the weight is close to the middle, so putting most of the drive train/electronics weight towards the back allows for more flexibility in weight distribution when designing manipulators. The tradeoff is less maneuverability if a chain comes off or breaks. |
#7
Looks good! I like your design. I would, however, encourage you to put the transmissions in the middle. It will help the chassis' ability to turn both from an inertia standpoint and from a "reducing scrub" standpoint.
How are the sections fastened together? O'all weight? Just a thought: some nuts like these fastened on the inside of your drive modules might be a great way to tie components/chassis elements together. http://www.aircraftspruce.com/menus/ha/nut_anchor.html I realize Aircraft Spruce isn't the cheapest place to buy things, but it's the first source that came to mind. |
#9
A properly designed and CNC machined drive train shouldn't need chain adjustment once the chain stretches. If careful attention is paid to ensure the sprockets are well aligned with an easy to use chain tensioner, then there should never be any broken/popped chains as long as you aren't exceeding the maximum force of the weakest link in the roller chain. A master link is only 60% of the strength of a regular link, but you can eliminate the need for master link if you use a tool like the DarkSoul chain breaker.
Also, you really should put the transmission on the center wheel, and drive the front and rear wheels via roller chains. It all comes down to reliability. In the odd chance a chain does fail, losing the chain between the rear wheel and center wheel would also take out the front wheel from the picture as well. By moving the transmission to direct-driving the center wheel, losing a single chain means only losing a single wheel. And because the center wheel can never lose power if a chain breaks, you'll still be able to drive whether you're tipped to the front or back. Quote:
#10
Very good point about the 6wd reliability. I would keep chain tensioners as an option, check out the AndyMark floating tensioners as a simple and cheap option. |
#11
It's always a good idea to keep spare parts just in case. Tensioners would be one more part to add.Last edited by Rion Atkinson : 05-17-2010 at 06:47 PM. |
#12
It's too bad about the out of stock issues; the one we picked up back in December has proven to be one of our most useful tools. If the DarkSoul chain breaks are no longer in production, it's not a very difficult device to reverse engineer and machine yourself on a milling machine. |
#13
| pic: Sheet Metal Drivetrain | Jacob Paikoff | Extra Discussion | 14 | 04-30-2010 11:21 AM |
| pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis | artdutra04 | Extra Discussion | 14 | 01-02-2009 02:11 AM |
| pic: New Chassis Concept | chris31 | Extra Discussion | 35 | 12-11-2008 11:43 AM |
| pic: 8WD 'Suspension' Chassis Concept | JesseK | Extra Discussion | 8 | 12-09-2008 10:00 PM |
| [OCCRA]: Bending Sheet Metal | troy_573 | OCCRA Q&A | 1 | 09-19-2005 10:27 PM |
