Go to Post its kind of a bad idea to implement traction control when you have no traction in the first place. - Uberbots [more]
Unread 16-05-2010, 16:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: CIM motor + Electrical outlet = ?
Would this work? http://www.harborfreight.com/1500-lb...nch-96127.html
Unread 16-05-2010, 19:58
AdamHeard's Avatar
Lead Mentor
Originally Posted by Chris is me View Post
If the circuit breaks at 40 amps, you wouldn't need a AC-DC converter that could output 1600 watts.
You'd still need a hefty one, and depending on the performance he wants, it could potentially be very annoying.
A 40 Amp breaker doesn't mean it trips at 40, it can hold currents above that for appreciable amounts of time.
Unread 16-05-2010, 20:01
Ryutso Ryutso is offline
Modularity, modularity, modularity
AKA: Toby Cubbin
FRC #0108 (Sigmac@ts)
Ryutso is an unknown quantity at this point
Originally Posted by sanddrag View Post
It works, but it's not really what I'm looking to do.
It does vertical motion, but it doesn't do the lateral motion around the pole that I'm looking for.
Any motor suggestions, that are just motors, that run off a 120V AC outlet?
Thinking of salvaging some household appliance motors like vacuums, or like someone said an HVAC motor if that would work.
Unread 16-05-2010, 20:49
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Why don't you separate vertical motion and lateral motion into two separate systems? You could have your TV mounted on a pivot bracket and adjust the angle with a fairly slow but powerful motor, then move the whole assembly up and down with a cable-elevator and winch?
No suggestions on AC motors. You could, however, get a battery enough to power the motors for a decent period of time (e.g. a FIRST battery, but smaller) and hook it up to a charging circuit, so the battery provides the current needed to run the motors and the charger recharges the battery at a slower rate then it is discharged.
Kettering Motorsports
Unread 16-05-2010, 21:07
Take a look around at www.surpluscenter.com
Unread 16-05-2010, 21:08
Or a bench grinder or skill saw or washing machine or sump pump or attic fan.
Unread 16-05-2010, 21:49
AKA: Toby Cubbin
I did think of that, using the two different systems, and it'd be so much easier to do, but I'd also like to do this method just to see if it's possible. I was also thinking of separating the systems in the same holding mechanism, so that it pivoted about a foot out from the pole, rather than around the pole itself, but I still think around the pole would be cooler to watch.
I'll keep that in mind, because doing 2 separate systems would be so much easier to actually accomplish.
I was thinking of something like that but I wasn't sure if it'd work. It's basically hooking a battery charger to a battery and then taking power from the battery as it charges, right?
Unread 16-05-2010, 23:15
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
You said you would be using a ball right? What happens when this ball slips? Feel like replacing the tv? Or will you have a safety system just in case?
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 16-05-2010, 23:20
AKA: Toby Cubbin
I was inspired by this video:
http://dvice.com/archives/2010/04/ball-balancing.php
So maybe something ball shaped but flexible so it can grip to the pole.
What do you recommend as a safety system?
Unread 16-05-2010, 23:31
Aren_Hill's Avatar
Build Nifty Things
i want one of these
http://www.youtube.com/watch?v=_i3zfL1VUGo
A guy who likes robots.
Unread 16-05-2010, 23:32
The CAD Guy
I'm not exactly sure... Some sort of friction system that activates after the tv stops moving? I'm not exactly sure... I would be using a completely different system... haha
Start Something
Unread 16-05-2010, 23:35
AKA: Toby Cubbin
Spring loaded rubber grips that lock on the pole? I could probably use a less powerful motor to hold those open and then when the motors stop moving, those could close.
Unread 17-05-2010, 00:18
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
use He to make the TV neutrally buoyant, then you could use almost any motor to use it. Or, use liquid He and levitate the TV on superconducting magnets.
https://www.surpluscenter.com/item.asp?Item=5-1677
Unread 17-05-2010, 01:41
Scott Bahl's Avatar
Scott Bahl Scott Bahl is offline
Go Spartans!
FRC #0971 (Spartan Robotics)
Scott Bahl is a glorious beacon of lightScott Bahl is a glorious beacon of lightScott Bahl is a glorious beacon of lightScott Bahl is a glorious beacon of lightScott Bahl is a glorious beacon of light
Ryutso,
If you get this system installed in your bedroom, I have GOT to see some pictures
Unread 17-05-2010, 08:02
Toby,
What you are asking leaves me wondering about safety. This is a point where we have to really point you to a mentor that can discuss this with you and watch over what you do. Household current is not something to fool around with as it can kill and set fires if mishandled.
As you can see from the above answers, four CIMs are an overkill for this project as you don't need to raise the TV that quickly. We typically are raising devices on a TV set at much less than one foot per sec and typically the height of the TV (30-40 inches) in about 15 seconds. Any faster and the support hardware and structure take too much of a beating when you stop. The garage door opener motor in the link that Sanddrag has given above looks like a pretty good start. Remember that the motor is designed to lift a balanced garage door so it is likely producing the required lift for you project. It might even have all the needed end limit switches that you should use in your project.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
CIM motor gearbox tseres Motors 3 22-05-2007 22:31
CIM motor on 30A jason701802 Motors 4 05-02-2007 20:23
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
CIM motor components natis Motors 4 13-01-2006 11:04
