Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
Unread 17-05-2010, 18:45
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
Programming EasyC
I am trying to use a digital I/O on the vex microcontroller to control a spike. Can someone help me with the programming. I understand all the drive functions, but dont understand how to use the digital to turn a spike on and off in easyC.
Thanks
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 18-05-2010, 02:23
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Programming EasyC
I don't know easyC, but I assume you know how to control digital outputs.
Referencing the Users Guide on the Spike product info page, the input cable to the Spike is wired so that the White (or Yellow or Orange) wire is the Forward signal, the Red wire is the Reverse signal, and the Black wire is ground. So you'll need to use two digital outputs and create a cable like such:
                 ,--W   \
                 |  R   |  digital output 1
                 |  B   /
         /  W----'
to Spike |  R----.
         \  B--. '--W   \
               |    R   |  digital output 2
               '----B   /
W,R,B = White, Red, Black
It might end up looking like a PWM Y-cable, but it is different. Then set the digital inputs as specified in the Users Guide to direct the spike into either Off, Forward, Reverse, or Brake modes.
Hope that answers your question
--Ryan
FRC 766, 2015-, Mentor
Unread 18-05-2010, 10:15
Using Ryan's wiring the code might look something like this:
Channel5=Get RxInput (1,5);
Channel6=Get RxInput (1,5);
if (Channel5 == 1) {
    // forward
    Set Digital Output (1,1);
    Set Digital Output (2,0);
} else if (Channel6 == 1) {
    // reverse
    Set Digital Output (1,0);
    Set Digital Output (2,1);
} else {
    // stop
Unread 19-05-2010, 14:05
mjgard's Avatar
Michael
AKA: Michael Gard
thank you both, i will try this.
Michael
FRC 2844
EasyC Pro Programming? Gizmo2417 General Forum 6 04-02-2008 01:08
EasyC Vex Programming help in RC Mode tommytalks Programming 7 06-12-2007 17:36
Programming help. EasyC Vex Robot. OneCoolDude Programming 2 02-12-2007 17:54
EDU programming with easyC SgtMillhouse648 Programming 4 11-07-2007 15:58
Arrays in Vex Programming Kit EasyC? gblake FIRST Tech Challenge 9 12-09-2006 17:05
