Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Unread 18-05-2010, 15:11
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: Weird Chain tensioner.
For a drive base with skid steer & direct drive for your center wheels I would agree with "joeweber" that there is no need for chain tensioners. When the chain stretches to a length you deem too loose, then change the chains out. The tensioner may give you the illusion that your chains are in good condition when in fact the chains are still stretching you just dont know how much. Dont get me wrong, tensioners are nice but in my experience they are not always required. But I also like #25 (1/4") chain for everything.
mike d
See Ya
Unread 18-05-2010, 17:43
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
mike d
At about $3/ft, throwing away stretched roller chain is a more expensive endeavor than installing a $0.50 chain tensioner.
Waste not, want not.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-05-2010, 18:03
Chris is me's Avatar
AKA: Pinecone
Would it be cheaper over time to break the chain and pull out a link, if this happened more than once?
Unread 18-05-2010, 18:53
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
you would have to remove at least 2 at a time and add in a half link, depending on the type of half link, you might have to remove three. Also, the chain might not stretch an entire link before it needs to be fixed. thus, you use a tensioner.
Of course, if there was considerable stretching, removing a section of chain would make sense.
Unread 18-05-2010, 22:48
artdutra04's Avatar
Unless the chain stretched a full two links, it's time consuming to take apart and would require the use of a half-link. A well designed chain/belt tensioner integrated into the rest of the system adds on a few ounces of weight, and can be tensioned in seconds.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-05-2010, 23:32
all hail Passmore
I was not saying to waste chain, but with or without a tensioner, the chain stretches close to the same amount. I would rather change the chain when it is determined to have stretched a given amount rather than to keep tensioning the chain until it fails. In my past experience, I believe having a chain fail during a match is priceless and would much rather spend the $3 per foot on chain. Each year we have used the same chains for two regionals, Atlanta, several off season season events, and quite a bit of testing with zero problems. This has been the case over the last 4 seasons and our 2008, 2009, and this years robot all have the original chains from build season.
mike d
See Ya
Unread 18-05-2010, 23:38
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
mike d
I completely agree with you and think this is true, so long as the chassis is extremely rigid. If the chassis has any amount of flex the looser chains could easily pop off of the sprockets. I know 233 uses box extrusion for the chassis which must make for an incredibly rigid setup not allowing for any misalignment.
Mentor 2415
Unread 18-05-2010, 23:56
Aren Siekmeier's Avatar
on walkabout
The last two years our team has used short segments of some Delrin rod we have lying around as tensioners. We mount the flat face of a cylindrical segment with a bolt off center, making somewhat of a cam, and then the round face is against the chain. The cam part allows us to just loosen the bolt, rotate the Delrin to retension the chain, and tighten it back up. Depending on the fastening method, the tensioner can rotate slightly when tight, which just means more frequent maintenance, but I think a little Loctite fixes this. This allows for an inch or so of tensioning and is fairly robust and lasts a while if done properly.
Attached is a screenshot of a rough CAD model of it in SolidWorks. The chain runs under the cylindrical Delrin rod, which is mounted horizontally to the aluminum angle which is then mounted to a frame rail or other structural element. You could even mount the Delrin straight onto the frame somewhere if it works out.
Unread 21-05-2010, 10:33
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
We have used this exact same setup ourselves for the two years we've been doing 2992. Also, those two years are the only years that we've not had a chain issue at all. Some sort of tensioner has been a lesson learned for us and something we plan to carry into the future.
As for the original post's floating tensioner, we used two very similar tensioners with great success on our super chain driven 2009 bot. They were made out of white nylon. Since we used them on the vertical positioned chains we didn't even have to move them or maintain them as gravity did that job for us. Here's a photo.
Unread 19-05-2010, 00:35
on walkabout
K.I.S.S. !!!
Unread 19-05-2010, 00:39
Aren_Hill's Avatar
Build Nifty Things
K.I.S.S. !!!
Pssshhhh
A guy who likes robots.
Unread 19-05-2010, 01:37
Brandon Holley's Avatar
I've built bots with extremely well thought out and elegant tensioners, and I've built bots with no tensioners (using "pre-stretched" chain). The thought out and elegant tensioners did their job, which when they're doing it, makes them almost unnoticeable.
The bots I've made without tensioners have also worked very successfully, to the point where it too was almost unnoticeable.
The point here is that you are addressing the facts and coming to terms with the fact that the chain needs to be tight. Some teams prefer to work tensioner free for one reason or the other. Some teams won't add a chain to a mechanism without a very well designed tensioner in place.
Personally, I think with a tensioner you are covering all your bases and it is the safest/most logical bet. The point of my post is just to acknowledge that the real problem is ensuring a tight chain.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 21-05-2010, 06:45
all hail Passmore
you guys win,
"chains must be tight",
tensioners for everyone.
mike d
See Ya
Unread 21-05-2010, 08:06
AKA: Sean
you guys win,
mike d
Ha your posts never cease to crack me up. I'm also a firm believer in not necessarily using tensioners. The only problem is without perfect alignment you're begging for trouble as a loose chain experiences much more shock loading than a tight chain. In my experiences, we have never broken a 25 chain though even when they were not tensioned properly.
Mentor 2415
Unread 18-05-2010, 18:26
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
our team always uses bicycle chain and i don't know what that is different, but the bicycle chain seems to work well even when semi loose, at least in one direction.
pic: Chain Tensioner gorrilla Extra Discussion 13 25-01-2010 00:13
Chain Tensioner RoboGeek99 Technical Discussion 23 12-01-2009 21:16
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
