Go to Post I have always gotten the answers I need. They're just not always the answers I want... - Alan Anderson [more]
Unread 18-05-2010, 07:14
carpenma's Avatar
carpenma carpenma is offline
<-- Ya, FIRST is on my pumpkin
AKA: Matt Carpenter
FRC #0548 (Robostangs)
Team Role: Webmaster
carpenma is an unknown quantity at this point
Send a message via AIM to carpenma
pic: Drivetrain Prototype
Unread 18-05-2010, 07:18
ttldomination's Avatar
Sunny
Re: pic: Drivetrain Prototype
Hm...
What's the diameter of the wheels?
And what is the effective wheel base?
A lot of robotics in '09 were wide based, so this stance might be alright. But some teams took *this* design even further and turned it into a 6WD.
And also, you have a lot of supports, or spacers, running along the top of the chassis, it might also be benefitial to put some support along the bottom.
- Sunny
1648: 2013-2014
5283: 2015
Unread 18-05-2010, 07:28
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Make sure you add some cross supports to the bottom of the two plates. Right now if that thing takes a hit it's going to bend inward.
Your sprockets look large, if you reduce the size of the sprockets both off the gearbox and on the wheel you can save some weight (and space) and keep the same ratio.
Unread 18-05-2010, 09:55
Best Available Data
FRC #1778 (Chill Out!)
I'm not particularly qualified to talk about drive chassis durability, so I don't have much to add.
However, I think I can save you some weight on this, or another drive train that you build. Having a pair of sprockets with built in hubs is heavy, and having those extra couple of inches of steel shaft is heavier. What you could do is take an AM hub and attach a pair of sprockets to it, spacing the sprockets with bits of plastic. Then just run enough shaft to cantilever the sprockets and hub.
A top down view would look like = []: () : ()
Where = is shaft, : are spacers, () are sprockets, and [] is the hub. Spaces are only there to prevent them from being turned into smilies.
Does that make sense?
Unread 18-05-2010, 12:32
You could save a bit more weight without losing much strength by changing all the X patterns into pairs of triangles. Your machinist will also thank you for doing that; fewer cuts means fewer opportunities for something to go haywire and less time before you get the plate back.
Also, I might ramp up the plate thickness a bit around high-stress areas--mounting points and axle attachment areas--or put a flange on, like you would do for sheet metal.
Unread 18-05-2010, 18:22
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
i would recommend against dually P80s. our team has used them in the past and found that they are hard to assemble, as well as grease migrating towards the motors and out of the planetary part of the gearbox. two single P80s would be better in my opinion.
Unread 18-05-2010, 18:24
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Two single p80's per side? Or two total?
Also, we have never had issues with our p80's, though is the first year we have used them.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 18-05-2010, 18:33
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
I would shy away from the p80's simply for the fact that the planetary transmissions are less efficient by design and arguably more fragile than standard toughboxes. You can easily buy all the parts necessary for direct drive from andymark as well and direct driving one wheel and chaining to the other would be the most reliable and lightest weight solution.
Mentor 2415
Unread 18-05-2010, 18:46
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
yup, as long as it's properly tensioned 35 chain.
Unread 18-05-2010, 19:08
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
I'm not sure why, but we always use 25 chain
Unread 18-05-2010, 19:16
25 chain is lighter, but less forgiving than 35 chain.
Unread 18-05-2010, 19:27
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Yeah, thats probably why. We also invest a lot of time in tensioning our chains perfectly, so we can get away with it.
Unread 18-05-2010, 20:16
AKA: Alan Wells
FRC #1350 (Rambots)
The issue is reliability, you can tension 25 chain properly, but then it stretches and falls off, with 35 chain, some stretching is more acceptable and doesn't need to be adjusted as much. If weight is your focus, and you have no issues getting things tensioned properly, than timing belts may be a better option as they don't stretch (depending on the material), but they aren't always as strong or reliable either.
Unread 18-05-2010, 20:25
NickE's Avatar
NickE NickE is offline
_
The issue is reliability, you can tension 25 chain properly, but then it stretches and falls off.
I have never seen a properly tensioned #25 chain break or fall off. Team 254 has been using 25 chain for years with no reliability issues.
Unread 18-05-2010, 21:04
I agree with Nick here. I've seen many people complain about reliability of 25 chain, yet I have yet to see my team have any problems with it. There has to be something you aren't doing properly.
pic: prototype drivetrain v2.1 548swimmer Extra Discussion 16 11-05-2010 09:05
pic: Prototype Drivetrain v2 548swimmer Extra Discussion 47 11-05-2010 01:13
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
