Go to Post I knew that the students on our team really understood what FIRST was all about when, two years later, our unofficial team motto changed from "we want to BEAT Chief Delphi" to "we want to BE Chief Delphi." - dlavery [more]
Unread 19-05-2010, 22:53
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Can I Make Something Clear?
Originally Posted by virtuald View Post
From scratch then? Alright, well why aren't you programming in assembly language then?
Yes, clearly it's important to know how things work and to be able to evaluate their performance. But from scratch, really? I'm going to use std::sort() on my std::vector<> full of dynamically allocated objects full of boost::shared_ptr<> objects long before I try to write my own sort function on a raw array that I have to manage myself along with all of the silly pointers for my dynamically allocated objects. It's just not worth my time.
Once you get to the real world, you will find there is a *huge* value to generic frameworks/libraries that already exist and have been debugged and well thought out (and theres even value in some of the ones that haven't quite been thought out all the way).
I believe that the WPILib is more than enough generic but more than enough to pull off an autonomous mode of this magnitude. Well IDK about you, but I feel way more accomplished if I do it from scratch. I rather program from scratch using OpenGL than use Irrlicht or Ogre3d or other stuff... Builds character
Can you add something to the spell checker? devicenull CD Forum Support 79 07-11-2006 10:35
Anyone ever make something rideable (go-kart/scooter/misc.) from the Kit Of Parts? Elgin Clock Technical Discussion 9 29-07-2004 22:09
Can we make a general science forum? Adam Y. CD Forum Support 7 27-12-2002 19:23
How can we make this better? archiver 1999 6 23-06-2002 22:39
Can someone clear up please? archiver 2000 1 23-06-2002 22:23
