Go to Post An inability to communicate your ideas effectively is a handicap you would be well served to strive to overcome. - Ether [more]
Unread 20-05-2010, 09:17
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: WCD Chassis Idea
Unread 20-05-2010, 09:26
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
Re: pic: WCD Chassis Idea
I like the cross braces, but the frame will have a tendency to twist without some more support.
Consider where chains/belts will run.
Also as someone suggested a while back, if you model your gearbox with all cims, you won't run into any space issues when you put in the fp/planet.
Unread 20-05-2010, 09:27
ttldomination's Avatar
Sunny
6 FP is a bit of stretch...isn' it?
1648: 2013-2014
5283: 2015
Unread 20-05-2010, 09:41
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Not necessarily; if it's their offseason prototype then perhaps they have many FP's lying around. They're easily swapped with CIMs if AM FP Planetaries are used.
I would consider trying to simplify the gearbox to two reduction stages instead of three. This may or may not interfere with an encoder mount on the output shaft, but the tradeoff is that it would lower all of the motors (and thus the c.g.) by an inch or two. I like the frame thus far though; adding a super structure for manipulators or cross bars at either end would solidify it enough I think. Given the previous years' bumper rules, those cross bars may also aid in compliance.
GitHub
Unread 20-05-2010, 10:27
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
If those cross braces are welded it will be a nightmare to keep your frame true and parallel without very good solid fixturing and welding.
The X-brace also lends itself to allowing you to get bent out of shape and not box when, not if, you get hit from both sides at the same time or sandwiched against a wall. It's a novel idea but I would at least put smaller crossmembers all the way across to make it practical for how rough the games are.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 20-05-2010, 11:08
The CAD Guy
I'll probably be taking the entire cross brace area actually. It's simply not need. And cutting holes in the metal for the chains would be a pain. It's easier to use the electronics board (The thing made out of glass right now) as the main structure.
With modeling with CIM vs. FP. It actually doesn't matter. I had those things with one CIM in it. Turns out the FP is only like a 1/4 inch shorter. So it doesn't really matter.
I was actually going to be changing it to a two speed gear reduction today.
As for the cross bars, I do believe you are right. I'll probably have some sheet metal fun and make the belly pan those cross bars as well.
Why would those braces be and harder to weld than anything else? (I'm not a welder so this is a legitimate question.)
I have a feeling that the biggest problems with bending would be on the outside edges rather than in the middle. Which as you said is easily fixed with more cross braces. Or as I said earlier. I belly pan.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 20-05-2010, 11:19
Joining the 900 Meme Team
FRC #0079
The volume of space taken up by a FP is significantly smaller than that of a CIM. This year at West Michigan we replaced a FP with a CIM and had to move around our compressor because two objects seem to have an aversion to occupying the same point in space. Long story short, model with the largest thing you might ever put in there and then be pleasantly surprised when you have extra space.
Last edited by Andrew Schreiber : 20-05-2010 at 13:58. Reason: Wow, I must have been half asleep, FP larger than CIM?
Unread 20-05-2010, 11:54
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
Team Role: Driver
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
usually how many CIM or FP motors are allowed during the FIRST competitions? I heard during the build for Breakaway that we could only use 5 CIM motors. So there would be a shortage of one motor for that system. plus, that uses up all of your allowed CIM motors. so there would be a bit of a sacrifice using those transmissions if your team needed a strong motor for another mechanism.
"To create a world where science and technology are celebrated... Where young people dream of becoming science and technology heroes"-Dean Kamen
This should start each year by focusing on worldwide issues, and having a game that, in theory if not practice, will help fix or compromise a solution with those issues, to make a better, safer worldwide and FIRST community.
Unread 20-05-2010, 13:00
The CAD Guy
Typically you are only allowed 4 CIMs. A lot of teams use all 4 in the drive train. The plan for this gearbox would be to use 2CIMs and 1fp for each one.
Can anyone tell me the typical limit on Fisher Price motors? (Or is there not one?)
Start Something
Unread 20-05-2010, 13:09
The reason welding would be difficult is you have to make sure you angles are perfect and lengths are identical. If you have any gaps the material will suck into the mating part during the weld and distort the frame. This is why you have to properly clamp and fixture everything.
If you clamp everything tightly,fixturing your angles correctly you can use welding rod to fill the gaps, that will probably be between the parts, and keep everything true. It is just not as easy and straightforward as most teams seem to go for. It is possible just not easy and you have to spend the time fixturing and planning before you weld so that the finished product comes out correct.
Thank-you 294 & 67
Unread 20-05-2010, 13:48
ADZDEBLICK's Avatar
this year and in years past we have been limited to 2 FP motors.
Unread 20-05-2010, 14:45
Instead of adding more crossmembers, you would be better off using the plans of a traditional WCD and add on a belly pan. Another version which I personally love is 418's, designed by roboticwanderer (Lewis). The combination of 2x1 and 1x1 allows for clean chain runs too.
http://www.chiefdelphi.com/media/photos/31575
Unread 20-05-2010, 14:57
2 FP's (or however many are in the KOP--typically 2, since at least 2004), 2 CIMs from the KOP, up to X (typically 2, but 3 in 2010) extra CIMs allowed.
To do this, you'd need 4 CIMs and 2 FPs, leaving 1 CIM, the window motors, the RS-55Xs, and pneumatics to do anything else you wanted to do.
Unread 20-05-2010, 18:34
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Looks awesome, Rion! Thanks for sharing with us.
I know you said the gearbox is still in development, but is it going to be a two-speed? I'm excited to see the final version!
Keep up the great work!
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 20-05-2010, 19:39
The CAD Guy
Thank you very much.
Yeah. I got to thinking about this after I posted it. RC gave me a few tips as well. The next version will have a belly pan.
It will indeed be a two speed gearbox. I'm taking the second stage out today, but yeah, two speed.
Start Something
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: Chassis Idea Rion Atkinson Extra Discussion 38 02-01-2010 04:56
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
