Go to Post Just be yourself, be honest, and most importantly, be present. The best role models are the ones you can relate to. - Jessica Boucher [more]
Unread 20-05-2010, 13:09
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: WCD Chassis Idea
Originally Posted by Formerly Famous View Post
Why would those braces be and harder to weld than anything else? (I'm not a welder so this is a legitimate question.)
I have a feeling that the biggest problems with bending would be on the outside edges rather than in the middle. Which as you said is easily fixed with more cross braces. Or as I said earlier. I belly pan.
The reason welding would be difficult is you have to make sure you angles are perfect and lengths are identical. If you have any gaps the material will suck into the mating part during the weld and distort the frame. This is why you have to properly clamp and fixture everything.
If you clamp everything tightly,fixturing your angles correctly you can use welding rod to fill the gaps, that will probably be between the parts, and keep everything true. It is just not as easy and straightforward as most teams seem to go for. It is possible just not easy and you have to spend the time fixturing and planning before you weld so that the finished product comes out correct.
Thank-you 294 & 67
www.bobcatrobotics.org
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: Chassis Idea Rion Atkinson Extra Discussion 38 02-01-2010 04:56
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
