Go to Post I guess what I am trying to say is that GP is inside all of us just waiting for a chance to escape. I am sure how the virus spread. I put the blame solely on the shoulders of Chief Delphi. - Ken Loyd [more]
Unread 19-05-2010, 20:20
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Re: Set computer to receive it's IP via DHCP?
How do you make the bridges new ip address to be compatible with your computer.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 19-05-2010, 22:28
If you connect and change the bridge IP to be compatible with the preferred robot setup, then after rebooting the bridge you must make your PC IP also compatible with the robot setup before you will be able to talk with the bridge again.
Assuming your PC is connected directly to the bridge...
After you set the bridge IP to 10.8.42.1
you must reset the PC IP to 10.8.42.6
then you should be able to browse to the bridge again.
Did you start from resetting both the bridge and router to factory defaults, or are you just resetting the bridge, since the router is probably fine already?
Unread 20-05-2010, 12:37
Rangel's Avatar
John Rangel
Hey, I've now configured the bridge and the router but the bridge doesn't have a green on the driver station
2014-? Mentor
Unread 20-05-2010, 13:18
Go through a similar process to setup the router.
After you reset the router did you:
  • Directly connect your PC to it with an Ethernet cable
  • Change your PC's IP address to 192.168.1.6 (or you can use DHCP)
  • Browse to IP 192.168.1.1
Unread 20-05-2010, 13:21
Do you have a green cRIO status?
The most likely reason for the bridge not being green is the IP address could be off (not 10.8.42.1). The green status is only if a device with that IP is found. Or your PC's IP address is not based on the same team number (10.8.42.5 for the Driver Station PC).
Unread 20-05-2010, 14:26
Rangel's Avatar
John Rangel
Hey I've reset the router and the bridge, followed the steps again, and tried connecting from the classmate to the router. Then tried connecting to the bridge but still no luck. We can get into the router and into the bridge but can't connect to the bridge from the router. Anyone know what to do?
2014-? Mentor
Unread 28-05-2010, 16:33
Rangel's Avatar
John Rangel
Does anyone know how to configure a router with Firmware Version: v1.0.04. Also, is it possible to downgrade it.
2014-? Mentor
Batch files to switch between DHCP and Static IP DtD Programming 9 28-01-2010 14:27
changing code after it's set to run at startup smcmahon NI LabVIEW 4 11-02-2009 19:36
How many IR Boards did you receive? SpaceOsc General Forum 3 22-02-2008 16:17
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
NJ Regional - Anyone like to receive us? Chuck[#1156] Regional Competitions 27 03-03-2004 02:58
