Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
  #46   Spotlight this post!
Unread 20-05-2010, 23:15
exprg:melonhead's Avatar
exprg:melonhead exprg:melonhead is offline
The Teamless/ Travelling Mentor
AKA: Justin Sticht
FRC #3278 (Qwerty)
exprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura about
Re: pic: A mechanum wheel that shouldn't bump around at all.
No, that's not what I said (not even close). I'm not sure how you concluded that from what I wrote. Help me understand what part led you astray.
ok. here's what confuses me. if i want a robot that drives just as easily sideways as it does front and back, would it be best to have a 45. because the way i see it, the more you get away from that angle, the more energy it will take to move it sideways. correct me if i'm wrong because i feel like i'm missing a huge part of the puzzle here. but i think i understand the most part. it's basic physics really.
sorry for the mis-wording on my last post. i was pressed for time. i meant to say "easily move forwards and sideways". it's not that i don't understand it, because i do. i just need it explained how it would be advantageous to set it at any other angle.
  #47   Spotlight this post!
Unread 20-05-2010, 23:22
Yes, that's probably a pretty good rule of thumb. You're on the right track. The important thing is to try to make the roller bearing friction as low as possible. For "zero" roller bearing friction, 45 degrees will make fore/aft and sideways motions equally easy. But since there is always some roller bearing friction, you might need to increase the roller angle slightly (make the roller axis closer to the wheel axis) if you want to make both motions equally easy.
You've got the right idea Justin. The more you get away from 45 degrees in one direction (i.e. smaller angle - roller axis becoming parallel to the plane of the wheel), the less efficient the sideways motion becomes. Moving the roller axis the other direction makes sideways motion more efficient - up to a point, depending on the roller bearing friction.
Take a careful look at posts 39, 41, 43, 44, and 45 in this thread - there's lots of good detailed explanation there. Ask questions about anything that's unclear.
  #48   Spotlight this post!
Unread 20-05-2010, 23:31
AKA: Justin Sticht
FRC #3278 (Qwerty)
thank you so much for helping explain this. i know it's hard to explain this through writing, and i know i don't usually learn well this way. you helped so much on clearing this up for me. i appreciate it.
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
