Go to Post Tinkerer math = engineer - MikeE [more]
Unread 21-05-2010, 07:21
Jared Russell's Avatar
Taking a year (mostly) off
Re: How Does My Distance Finding Method Look?
If you know Angle 2 (based on servo measurement) and you know Angle "3" (the right angle), then there is a far more efficient way to find Angle 1.
Unread 21-05-2010, 09:21
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Angle 1 = 90 - Angle 2
I knew that
Unread 21-05-2010, 11:23
Back after 4 years off
FRC #5279
Could you explain the drawing better, ie, where is the robot, what is it's orientation, and what are you trying to find.
My original assumption is that the robot is essentially the Bule box in the corner (where the range finder is) and that it is pointed at the wall. I am guessing this is wrong, I think there may be a better way to solve this problem based on how you use your sensors but I need to know more about what I am looking at.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 21-05-2010, 18:12
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I was thinking about it in school today, yea, my diagram need more info. My goal in teh short term is to be able to render a 3d image on screen with the info I get from the sensor. It sounds complicated but not really. I can get the x, y and z coordinates of the point just using trig.
Unread 24-05-2010, 08:37
FRC #5279
It is pretty complicated, it may seem fairly simple but in practice it isn't. It is even more difficult since in FIRST we can't use laser range finders. IR, and Sonar range finders introduce a lot of noise.
If you are serious about looking into this in more depth research SLAM ( Simultaneous Localization and Mapping). Nearly every University with a robotics lab is doing some level of research on SLAM algorithms, this alone should be enough evidence to show you that this is not a trivial problem.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 24-05-2010, 08:58
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
For noise --- running a rolling average (16x or higher oversample) tends to level out most noise issues, although it does slow down response.
SLAM is much easier in a FIRST enviroment where the initial map is known, the objects sizes (other than other robots sizes) are known (and possibly fixed in position), the initial position and orientation (as well as size) of the robot is known, and the driving characteristics (drive train characteristics, turning radius, etc) of the robot are known. While it is not trivial ... it is doable in a FIRST enviroment.
___________________
- Tennyson, Ulysses
Finding distance using accelerometer.. SL8 NI LabVIEW 5 13-02-2009 16:20
What does your OI Look Like Cow Bell Solo Control System 9 29-02-2008 02:13
Does this look familiar to anyone? ebmonon36 Chit-Chat 9 29-04-2007 12:45
pic: Does this look like Dean? Cody Carey Extra Discussion 19 18-03-2007 23:27
Does this look real enough? TheFork 3D Animation and Competition 6 08-03-2003 00:19
