Go to Post A better way would be better..... - WizardOfAz [more]
Unread 21-05-2010, 10:13
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
Re: New Programming Manual
It seems to me that an accelerometer wouldn't be a common sensor for a beginner programmer to use.
- That said, does anyone have an excerpt of code I could use?
And here is a more recent copy of the manual. (accelerometer section is blank. Working on a good way to explain it. I think I might use Jared's explanation)
ALWAYS a mechanical problem!
Unread 21-05-2010, 10:32
rhoads2234's Avatar
AKA: Erin
FRC #2234
Sorry. I didn't realize that moving the document from word 2007 to 2003 compatable would make the page numbers be all funky. I've fixed it for the next version, but I am going to wait until I have a few more changes before post the new one.
Unread 21-05-2010, 11:39
rhoads2234's Avatar
AKA: Erin
FRC #2234
I realized I forgot to add encoders on the sensor list. They are now included!
Unread 21-05-2010, 22:00
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
I know this is a nerd turf war thing (http://xkcd.com/743), but can you please use a more open document format? It is about 1.5 times faster for Word to read OpenDocument Text than its own format (ROFL).
And I use OO.O, and disabled m$ compatibility.
Unread 24-05-2010, 09:30
rhoads2234's Avatar
AKA: Erin
FRC #2234
Here's the newest version - I've started adding in pictures.
Note: I will move the Tabbing section. I just wrote it, so right now it is at the bottom. It will soon be higher up.
I'm still looking for accelerometer code - If you have it in C++, I can just do the small changes to make it into Java.
If you have anything you'd like to see added or clarified, please PLEASE tell me!
Unread 24-05-2010, 09:33
rhoads2234's Avatar
AKA: Erin
FRC #2234
How do you convert it from a Word doc to OpenDocument? I didn't see how.
I can easily convert it to a pdf if that would work for you. - Why would you disable ms compatablity? A lot of places send their stuff in MS office formats.
Unread 24-05-2010, 09:44
rhoads2234's Avatar
AKA: Erin
FRC #2234
I don't recommend printing it out yet, I thought that the page references would automatically update, but turns out that they don't, they still link to the right spots in the text, but the numbers themselves are wrong. That'll be difficult to fix, but it should be good (mostly) by the next version.
Unread 24-05-2010, 14:20
1 * 4 != 14
hit ctrl-shirt-s, choose odt
Unread 13-01-2011, 00:26
msheffels msheffels is offline
AKA: Mike
FRC #2498 (Bearbotics)
msheffels is an unknown quantity at this point
Originally Posted by rhoads2234 View Post
I I thought that the page references would automatically update, but turns out that they don't,
You set up the links correctly, but MS Word doesn't update automatically. Highlight the text with the link (you can "Select All" for the whole document) and hit F9 to "update field codes". I tried it on my downloaded copy and it seems to work fine.
Unread 24-05-2010, 15:17
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
You seem to be using an older version of Word (hence the .Doc and not .Docx format). Word 2003 and prior doesnt convert to OpenDoc format. I'd suggest you not convert to openDoc anyways as the formatting can become Borked, and instead convert it to a .PDF (use CutePDF writer, it's free and works great ... to the PC it's just another printer) and post it in that format since most can get an acrobat reader free, if they don't alreadyt have it.
___________________
- Tennyson, Ulysses
Unread 25-05-2010, 08:52
rhoads2234's Avatar
AKA: Erin
FRC #2234
I'm using Word 2007, but Delphi doesn't accept the .docx file extension.
I'll post it in a pdf once I finish making some corrections I caught. (maybe 20 minutes?)
Unread 25-05-2010, 09:31
rhoads2234's Avatar
AKA: Erin
FRC #2234
So I explained a couple of things better, changed to a table of contents and fixed the tabbing and colors that got messed up.
I've included both a .pdf and .doc version of the manual. They *should* be the same....
Unread 26-05-2010, 08:56
rhoads2234's Avatar
AKA: Erin
FRC #2234
There were a couple "reference cannot be found." I fixed that (I hope) and added in a section on Versioning.
Unread 26-05-2010, 19:08
1 * 4 != 14
if you are using word 07, please use ODT. Some people disable .doc file parsing to save about 30 MB of memory per session (on average).
Unread 27-05-2010, 11:16
rhoads2234's Avatar
AKA: Erin
FRC #2234
I've rearranged some of the sections, and added one on a Timeline and another on Competition tidbits.
EDIT: I still haven't been able to find the option to save as ODT. I hope that everyone can at least read the pdf.
Changes in the New Revision of the Control System Manual mcf747 General Forum 2 07-12-2008 22:10
Completely new to programming robots... Comatose Programming 4 19-09-2008 19:22
The complete FIRST Programming manual project David55 Programming 3 02-07-2006 21:38
Is there a manual for the new default code somwhere? Anton Programming 1 16-01-2005 16:34
New programming resource rbayer Programming 0 03-12-2002 00:14
