Go to Post If you never takes steps to solve problems you cannot just complain that they exist. - Wayne C. [more]
Unread 21-05-2010, 12:04
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
Re: Learning Autonomous Mode?
We implemented a recording system for our robot this year. It is written in C++, as well as in Java. The main reason was to allow us after a match to review what happened out on the field. So we captured all user and senor data, and stored it in a text file. After implementing the recorder, we verified that it had minimal impact on the run time behavior of the robot. Each record contains a timestamp, and is written only when the user inputs change. There's plenty of flash disk space, so this was never a problem. But a match would have 1000's of records.
With the recorder in place, we then proceeded to write a replay function. The file can be read, and the data used to replace the users specified actions. For the first version of the code, we simply ignored the sensor data. This, as has been pointed out, leads to the robot not quite doing the exact same thing every time. Without sensors, you are using time as a means of controlling behavior. 3 seconds forward, 2 seconds back, etc. Since the mechanical system has quite a bit of variance, this isn't particularly accurate. This can be enhanced by using the captured sensor data. Say you have a gyro, and you record the gyro data. Then during replay you can compare the current gyro data to the recorded data, and if they aren't the same (within some epsilon), you adjust the movement of the robot to compensate for the drift.
Finally we then had our driver, do what we wanted for our autonomous mode. Pulled the file off the CRIO, cleaned it up a bit, and then saved it on the CRIO as autonomousXXX.txt. Then all our autonomous code did was read a switch that indicated what autonomous file to run, and opened the file and replayed it.
At the end of the day, there is a lot of uses for the record data, above and beyond just finding out what the robot thought it was doing out on the field.
Some that are on our todo list:
1) Macro actions, saved as files and replayed.
2) Creating a simulation so we could replay the files and see what happened during the match.
---Michael J Coss Lead programming mentor for team 303
Unread 21-05-2010, 12:49
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
I'm wondering if you would be willing to contribute this to the Bobotics ADK or open sourcing it so I could? This is one tool I'd like to provide to all teams.
Unread 21-05-2010, 14:34
FRC #0303
Sure. It needs cleaning up, and as I said, it right now just replays joystick data and ignores the sensor data. I really wanted to make it a bit more flexible with regards to the data capture (what get's capture, and when), and how the replay works. It's going to be my summer project.
---Michael J Coss
Autonomous Mode jamie_1930 Rules/Strategy 15 29-01-2010 18:21
Autonomous Mode fallen751 Programming 14 09-02-2007 00:28
Autonomous mode HellBoy Programming 4 07-02-2007 18:22
Autonomous Mode David Bryan Programming 1 21-01-2003 21:15
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
