Go to Post To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. - Al Skierkiewicz [more]
Unread 10-05-2010, 08:46
kevin_m kevin_m is offline
kevin_m is an unknown quantity at this point
using legacy hardware
hi i am in a grade 12 compeng class and i want to use the old controllers for my project. i have the 2008 models and i got some code from kevin.org but i'm getting build error from mplab i think i have the wrong compliler. can any one tell me what compliler i need.
the error i get is "Error Coff file format for ifi_library.o is out of date"
at the current moment all i want to accomplish is getting the bot to move with the joysticks
Unread 10-05-2010, 10:04
Re: using legacy hardware
It's the version of MPLINK that doesn't match the C18 compiler version used to compile ifi_library.o
"Due to a change in COFF file format, MPLAB C18 v3.00 and later will
not be compatible with versions of MPLINK prior to v4.00"
The original ifi_library.o was compiled with C18 v2.4.
Kevin did provide an updated version of the ifi_library.o compiled under C18 v3.
Look in the workspace directory for Kevin's project and you should see both:
  • ifi_frc_8722_24.lib
  • ifi_frc_8722_30.lib
In your MPLAB project file list under "Library Files" one of these two files will be listed. You probably just need to swap to the other file. Click on the name in the file list and delete, then go to Project -> Add Files to Project... and browse to the file you want to use. When browsing you'll need to specify "Files of type: Library Files (*.lib)"
Unread 21-05-2010, 12:53
Kevin Watson's Avatar
La Cañada High School
FRC #2429
I just dusted off an old IFI RC and found that my code built and ran just fine with the latest version of the Microchip C18 compiler (v3.35) and MPLAB (v8.50).
-Kevin
Kevin Watson
http://kevin.org
RC Hardware CPress Control System 2 10-01-2008 12:07
Anyone actually using hardware timers? Spencer E. Programming 20 27-03-2007 12:43
Share Galileo's Legacy as Mission Nears Its End geo Chit-Chat 0 21-09-2003 12:19
hardware ...? Martin Rules/Strategy 2 13-01-2002 00:07
hardware Amadkow 3D Animation and Competition 1 25-06-2001 11:05
