Go to Post Football has been a school institution for over 100 years--we can't expect FIRST to show the same potential in a 10th of that. - Petey [more]
Unread 21-05-2010, 19:58
Stephi Rae's Avatar
Stephi Rae Stephi Rae is offline
Lets play robots!
AKA: Stephanie Morrison
FRC #5803 (Apex Robotics)
Stephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to behold
Send a message via AIM to Stephi Rae
Re: pic: My First WCD
I'll try to answer most of your questions here.
I apologize I got the terminology a little mixed up.
Dave is correct, this is not a sheet metal drive, it is 1/8" 3x1 C channel. It is a little difficult to see in the picture, I apologize. If I have some time later, maybe I'll render a few other perspectives and post them.
It is all C channel. The idea I took was to make things easy to manufacture and easy to get to. All four side rails are completely identical. Front and back are identical as well.
Everything except the outermost side rails would be welded together, and the outermost rails are bolted on via standoffs and brackets at the ends/corners. This would make the outer rails easy to take off and maintain the drive, if necessary. If weight became a concern, these would be replaced with polycarb, as many teams have done previously.
The outer rail channel has cutouts around each of the wheels.
Inventor says the frame is around 10 lbs. Like I mentioned before, there are things that could easily be changed if weight became a concern.
As far as the trussing and cutouts go, there is at least 1/4" material between every cutout, often more.
The wheels are 50 durometer Banebots wheels with the unfinished hubs. There are custom hubs that interface with the wheels after they have been modified to have a larger hole. Outer wheels are dead axle, center are keyed.
There are vertical slots in the side rails that hold a chain tensioner.
I'm not really sure what you're asking 548swimmer, but the wheels are all inline with each other and the center wheel is exactly in the center of the robot.
If I missed a question, or if you have more, feel free to bring it up again, or ask.
~Stephanie Morrison (Hoag)~
Student - Team 1983 (2007-2008)
Mentor - Team 190 (2009-2012)
Mentor - Team 1983 (2013-2014)
Mentor - Team 1318 (2015)
Coach - Apex Robotics 5803 (2016-Present)
Unread 21-05-2010, 20:20
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
If all your wheels are in line with each other you will not be able to turn. you need to lower the middle wheel so there are never more then 4 wheels on the ground at a time.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 21-05-2010, 23:19
Stephi Rae's Avatar
Lets play robots!
By inline I was trying to address the question that swimmer posed, but I'm not really sure what he was getting at. If you'll notice in the description of the picture, the center wheel is dropped 1/8".
Unread 21-05-2010, 23:50
Edoc'sil's Avatar
FRC #2531
Sorry I assumed that was what he was referring to. I did read you OP but is was a few days ago and I totally forgot. I have no idea what swimmer meant, he is hard to follow at best.
Unread 22-05-2010, 00:55
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Really Cool Chassis and a great start.
A Few Suggestions:
-Ever thought about riveting it all together and then adding a few welds? It would help make it easier to assemble and easier for our welder. We did that this year with our bottom part of our chassis.
-I would honestly pocket less. Its often way stronger to leave it unpocketed. I mean your only losing so much weight. Around the wheels and gearbox I would honestly unpocket it.
-Also wheels selection, why banebot wheels. We bought some a few years ago and the tread seems to wear very easily unless you get a high durometer. They are cheap, but I would switch to pneumatic wheels or Colsons. I'm sure Sean (1771) or someone can elaborate on Colson wheels.
A Few Questions:
-What gearbox is that: ratio, output speed and weight?
-Are you planning to mount electronics somewhere?
-For the chain tensioner, are you pinching the chain down or stretching it up?
Good Job and keep having fun.
-RC
R.C.
MadTown Robotics Team 1323
Unread 22-05-2010, 01:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Colson wheels are very cheap (usually between $5 and $7 each), and can easily be adapted for a live axle drivetrain. The stock Colson wheels usually have a large ID shaft hole in the center that needs to have an adapter made to fit 1/2" or 3/8" shaft. We use 6061 aluminum for this adapter plug. Simply turn it on a lathe to a slight interference fit, and knurl the outside. Drill out the center and broach with either a keyway or hex broach. Use an arbor press to insert knurled plug into wheel. Done.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-05-2010, 14:15
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I would definitely recommend colsons as well. We did the same thing as art this year. Bought stock colsons and put hubs in them. They work great and are designed for durability whereas the banebot wheels are basically childs toys. I've seen and heard of way too many failures/manufacturing inconsistencies with the banebots to ever consider them.
Mentor 2415
Unread 23-05-2010, 15:15
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
With the holes on the side plate, it looks like you have two holes to press-fit bearings for the center wheels into. This led me to believe that your center wheels were not on the same line in the center of the 'bot. Also, from this render it looks they don't quite line up (again with the two bearing holes). I trust you that they are in the center, but it was just a concern I had at the time.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 23-05-2010, 16:35
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Ditto on the Colsons, they are very robust wheels, and have a great grip on the carpet. However they do become pretty heavy when you start adding in the additional parts needed (ie: plug adapter for each wheel). Just another thing to consider in wheel selection.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-05-2010, 17:19
Chris is me's Avatar
AKA: Pinecone
I've never seen Banebots wheels used successfully in a robot. I've heard of teams getting them with the bore off center by as much as half an inch. I've seen teams make them fail with only 3 seconds of load. I would go with AM, Colsons, your own wheels, etc. (or if you want to be super cool, take a scooter wheel and put it on your robot!!! no traction but who cares, they're awesome!)
pic: WCD Chassis Idea Rion Atkinson Extra Discussion 22 21-05-2010 14:17
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: me (Leav) getting some water while MCing at the first FIRST off season event in Israel. Leav Extra Discussion 3 17-12-2007 23:18
pic: FIRST in theyre blood...the first meeting Rohith Surampudi Extra Discussion 14 11-11-2006 21:15
pic: My first National FIRST T-shirt Day CD47-Bot Extra Discussion 13 07-09-2004 18:50
