Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 22-05-2010, 13:58
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Most Powerful FIRST Team created T-Shirt Cannon
Lets consider PVCs pressure rating for a moment. PVC is only pressure rated for liquids (and for a very good reason):
Water is incompressable, much like a steel block ... if you push down on a steel block with 50 PSI it will not compress and if you release that force instantly the steel block will not move.
Air, on the other, hand is compressable, like a 50 pound spring. Apply 50 psi to it and the sprin compresses. release that force instantly and the spring not only goes back to it's original shape but rockets off of the surface it was on.????
Umm Yeah the principle of compressing water has to happen other wise when you put your finger over the end of a hose nothing would happen. Water is compressable. 1000psi water jets are used to cut steel.....so again logic isn't following here. It's compressable to a very very small degree.
John Fogarty
pic: TEAM 343's t-shirt cannon Josh Drake Extra Discussion 14 20-04-2009 18:58
IRI T-shirt cannon Kyle Love Off-Season Events 6 17-07-2007 12:09
Too Powerful cannon? I Eat Robots829 Chit-Chat 15 03-02-2006 00:19
What is the most benefitial technological advance ever created? Koko Ed Math and Science 28 05-05-2005 22:52
What is the most obscure technological advance ever created? Allison K Math and Science 4 30-04-2005 15:09
