Go to Post I was proud that there was no whining, no finger pointing and no complaining. - Vikesrock [more]
View Poll Results: How do you make your robot?
Just kit of parts 4 2.96%
Kit and 8020 21 15.56%
Welded square stock 38 28.15%
Sheet metal (outside manufacture) 20 14.81%
Sheet metal (we cut the parts) 13 9.63%
Other 39 28.89%
Voters: 135. You may not vote on this poll
  #31   Spotlight this post!
Unread 04-05-2010, 21:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: How Do You Make Your Robot?
2006: Welded Aluminum (box, angle, 1/8" plate); 1/8" plate and 1/2" tube for mechanisms
2007: Welded box aluminum, and it took the welder 3 tries to get it right without warping; 1/4" thick honeycombed fiberglass for the ramps with KOP U channel for structure bolted to the frame
2008: Welded box aluminum, simple design; 80/20 for elevator and it was heavy, too much to maintain, and very innefficient
2009: Welded box aluminum frame; riveted plate gussets to mechanisms; used honeycombed aluminum for the floor of the bot
2010: Welded box aluminum for the frame; waterjet plate for precision mechanism parts;
2011: Most likely we will use box aluminum, welded by a sponsor again. However, during the offseason we will experiment first. We've toyed with prototypes that use C-Channel and cantilevered wheels since 3" C-Channel provides a perfect mounting channel for the AM SuperShifter. However, we like our 2010 direct-drive system, so we may to 1" box Aluminum and some waterjet plates. We have excellent CAD students this year and a potential sponsor with a waterjet so we will see what else we can do with it and 1/8" or 1/4" Aluminum plate.
2017 Scoring Model
CAD Library | GitHub
  #32   Spotlight this post!
Unread 19-05-2010, 10:01
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Team 1306 uses mostly the C-channel from the KOP and 80/20, but also angle aluminum, flat aluminum (1" width for both), plexi, aluminum plate, a bit of PVC, and (as a last resort only) plywood
This year's robot contained all of the above (I hated having to use the wood to mount electronics and penumatics, but we were short of time)
  #33   Spotlight this post!
Unread 19-05-2010, 10:14
Joining the 900 Meme Team
FRC #0079
Just a quick comment; Wood, when used properly, can be an effective solution to a problem.
  #34   Spotlight this post!
Unread 19-05-2010, 10:27
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
One of my firends favorite quotes:
Wood, its natures carbon fiber!
When you look at it that way, it is a much more attractive option.
  #35   Spotlight this post!
Unread 19-05-2010, 13:28
JohnFogarty's Avatar
AKA: @doctorfogarty
For us it has changed every year, In the begining we welded 2mm sheet metal aluminum to make our frame, the we used 5in think 2x4, then the last 2-3 years we've used 80-20, sheet metal, Polycarbonate, even steel once.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #36   Spotlight this post!
Unread 19-05-2010, 16:46
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Since 2001 our team has used welded aluminum square stock with lots of bolt on arms and manipulators.
Lately we have been powder coating and experimenting with sheet metal.
  #37   Spotlight this post!
Unread 20-05-2010, 09:46
CENTURION's Avatar
Yes, I guess so, I'm more worried about looks (I'm the teams *unofficial* lead graphic designer, and I'm terribly OCD about things like that)
  #38   Spotlight this post!
Unread 20-05-2010, 09:58
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Im going to have to question your comment about wood not looking good
http://picasaweb.google.com/lh/photo...eat=directlink
Mentor 2415
  #39   Spotlight this post!
Unread 20-05-2010, 11:31
FRC #0079
Say what? Can you tell me which parts of those twins are wood and which aren't? Looks pretty good to me.
Eric reminded me, http://www.chiefdelphi.com/media/photos/31598 Quite possibly one of the most visually appealing frames I have seen in a while.
  #40   Spotlight this post!
Unread 20-05-2010, 15:14
Can you tell what parts of this are wood/not wood just by looking?
http://www.chiefdelphi.com/media/photos/32851 http://www.chiefdelphi.com/media/photos/32671
And, does it not look good?
I don't think there are any pictures out there of 330's underside in 2007, but if you looked at it, it was wood, hogged out to reduce weight. (Areas connecting fasteners remained at full thickness.) Other robots used wood baseplates; 2005 had a built-in notch to help interface with the frame.
  #41   Spotlight this post!
Unread 21-05-2010, 10:07
CENTURION's Avatar
Ok, that's fair, I see what you mean.... It's just that whenever we use wood, it looks like junk. We only use it when we really don't have time to put together anything else, so we definitely don't have time to finish it and make it look that pretty...
And maybe I's just my personal dislike for it I much prefer aluminum and plexi.
  #42   Spotlight this post!
Unread 21-05-2010, 10:54
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
How FIRST-typical of you
  #43   Spotlight this post!
Unread 22-05-2010, 12:26
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We use welded aluminum T-Slot extrusions.
  #44   Spotlight this post!
Unread 22-05-2010, 19:21
Phreadumb's Avatar
Phreadumb Phreadumb is offline
FRC 2188 Alumnus
AKA: Dakotah Jones
Phreadumb has a spectacular aura aboutPhreadumb has a spectacular aura about
Re: With Fun!
For those looking for a more pragmatic answer:
My team used 80/20. Now I can't completely defend the use of this product because I myself would much prefer the use of customized sheet metal parts, but the reasoning behind its use was for its easy configurability and ability to reconfigure if necessary. So basically it saved building time, maintenance time, and was overall easy to use and assemble.
I will be trekking into territories where FIRST teams do not exist, perhaps I should start one? Oh, but that's a lot of work.
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
How do you make the robot turn a perfect 90 eccmaster Programming 2 16-01-2008 20:54
How did you make your team insignia? vivek16 General Forum 8 24-02-2007 00:20
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
