Go to Post Unfortunately our team missed out on a great opportunity to "learn from the pros" because we did student-centric things like insisting on having a student field coach. - Tom Bottiglieri [more]
Unread 22-05-2010, 14:14
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Most Powerful FIRST Team created T-Shirt Cannon
Would lamination (with carbon fiber or fiber glass) prevent fragmentation? Metal Mesh?
Unread 22-05-2010, 14:26
JohnFogarty's Avatar
AKA: @doctorfogarty
I may end up making my half inch thick lexan boxes after all, We probably won't be able to replace the PVC but i'm going to install bulletproof box around them for saftey. The dump tank on the gun however i'm not sure yet.
http://maikenmagic.com/?ref=gallery&...irt%20Launcher
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 22-05-2010, 14:43
Best Available Data
FRC #1778 (Chill Out!)
Originally Posted by Daniel Lafleur
Lets consider PVCs pressure rating for a moment. PVC is only pressure rated for liquids (and for a very good reason):
Water is incompressable, much like a steel block ... if you push down on a steel block with 50 PSI it will not compress and if you release that force instantly the steel block will not move.
Air, on the other, hand is compressable, like a 50 pound spring. Apply 50 psi to it and the sprin compresses. release that force instantly and the spring not only goes back to it's original shape but rockets off of the surface it was on.
I still don't see how that contributes to making the material fail. I can see how it would make the failure explosive, but it seems to me that if the gauge reads 100 psig, there is a net force on the tank walls of 100 lb/in^2, no? If not, how does the compression add a force that the gauge doesn't see? Don't pressure gauges just measure the deflection of a spring?
Unread 22-05-2010, 15:45
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I think the real problem is the 'glassy' behaviour of PVC at room temperature. This is a characteristic of the polymer, and means it will fail in a brittle manner (fatigue and brittle fracture, neither of which would be non-catastrophic in a pressure vessel) rather than the ductile failure mode of a tank made of most metals or a different plastic.
I don't get why people choose to build a PVC air cannon after all the warnings that have come out over the years. There has to be a safer way of doing this.
EDIT: fatigue is based on the pretty much uncontrollable microcracks in your material, it could fail after 1 cycle or a million, and it is pretty much impossible to tell when it will fail.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 22-05-2010, 16:38
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Eye protection too, please. If this thing fails in the way people have been describing it may be the last thing your operators see!
Unread 22-05-2010, 18:30
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by sdcantrell56 View Post
Water is most definitely incompressible.
Originally Posted by John_1102 View Post
Umm Yeah the principle of compressing water has to happen other wise when you put your finger over the end of a hose nothing would happen. Water is compressable. 1000psi water jets are used to cut steel.....so again logic isn't following here. It's compressable to a very very small degree.
You are both mistaken.
SDCantrell - Water will compress when you press upon it, just like every ordinary real material will. However, as John said, it compresses very little, and for that reason pretending it is incompressible is a useful approximation.
John - Water's compression has nothing (or at least very little) to do with whether a 1000psi waterjet can cut something. That pressurized water will fly out of a nozzle and cut things is a separate topic from how much or how little it's volume changes when it is put under pressure.
Blake
Unread 22-05-2010, 19:26
To be very blunt about this, can people please stop being unintelligent and just purchase something that is certified for air pressure instead of just assuming it will work for an air cannon?
Your robot for demo's doesn't need to come under any weight constraints so feel free to use a high capacity, industrial, CERTIFIED, tank.
ie: http://www.toolsoutlet.ca/osc/images...ank%20copy.png
Here's your testing: http://www.youtube.com/watch?v=Cal71EN5Gt8
Or you could be idiots like these guys and laugh about it: http://www.youtube.com/watch?v=AQo81...eature=related
Have fun with the shrapnel.
Unread 22-05-2010, 19:41
AKA: @doctorfogarty
You commentary is unnecessary..we are having an intelligent discussion about why the dangers occur. I'm going to be getting our 1600psi firefighter air tank to use. soo thank you.
John Fogarty
Unread 22-05-2010, 23:19
foote stepped in
AKA: E. Foote
FRC #0868
The point everyone here is trying to make is better safe than sorry. Your PVC may be rated for pressure on the inside, but what happens when you've used your gun time and time again? You know, storage, moving it from place to place. What if you drop it? Chances are you'll make defects in the exterior, and it'll weaken as time goes on.
Your cannon has a chance of failure. What happens after failure is shrapnel, bits of plastic flying in every direction at ridiculous speeds.
By definition, liquid water isn't compressible (liquids have a definite volume). Since water doesn't violently expand or change shape when its depressurized, there is no chance that it'll take the plastic with it.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 23-05-2010, 00:27
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
A good way to win the Darwin Award?
This message is hidden because Jack Jones is on your ignore list.
Unread 23-05-2010, 01:13
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Last I checked, liquid water IS compressible, just very little. Heck, a solid steel block is compressible, you just need to apply enough pressure
Call me a bit of a n00b, but I'm not sure I see the difference between water pressure and liquid pressure, PSI is PSI, no matter what is CREATING the pressure on the walls of the PVC, the pressure is still there, and (assuming it is regulated) the same amount in both cases.
I understand that the PVC wouldn't be safe in this situation, I just don't really understand the difference between the ratings (liquid vs. air)...
Unread 23-05-2010, 01:28
EricH EricH is online now
It's how it fails that's the issue. Water, you get an incompressible (or close enough as to be easily approximated as such) fluid that, if it's under some pressure (as it might be in a sprinkler system), and it gets an outlet, it will leave in a reasonably orderly fashion, spraying out until somebody turns the water off.
Air, on the other hand, will try to all leave at once, causing further mayhem as it breaks whatever it's in further. If you have something that's rated for air, presumably it would have failure modes to safely release the air even if something breaks.
What we're concerned about is the "mayhem" as the PVC breaks. I've seen PVC that's fallen from a height of about 3.5' break (fortunately, no pressurized air inside).
Unread 24-05-2010, 17:02
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Just to clear things up- The water in your hose wants to leave the hose at a constant rate. For example, lets say 5 gallons a minute. Now, if you have a one inch diameter opening at one end of your hose, the water will come out relatively gently. If you shrink that opening (such as with your thumb), the water still wants to exit the hose at 5g/min, but because the opening is now smaller, it must exit faster, and thus with more force.
On a side note, our team operates our tshirt cannon off a 5-gal tank designed for air pressure (craftsman tank, I believe). It works fantastically well. PVC can not only fail in the piping itself, but it is also highly susceptible to end caps and joints failing.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 24-05-2010, 17:28
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
You should listen to Akash, he does know what he's talking about.
I'm glad to know that your getting a metal airtank It's alot easier to spend some money and be safe, than to pay a hospital to fix you.
By the way, a SCUBA tank would work fine, it holds more air at 3000psi, and is way more safe than any PVC storage tank you could practically come up with. Plus they have standard size fittings!
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 25-05-2010, 12:51
AKA: @doctorfogarty
That's what we are going to use until we get a new tank, this one is rated 2560psi
John Fogarty
pic: TEAM 343's t-shirt cannon Josh Drake Extra Discussion 14 20-04-2009 18:58
IRI T-shirt cannon Kyle Love Off-Season Events 6 17-07-2007 12:09
Too Powerful cannon? I Eat Robots829 Chit-Chat 15 03-02-2006 00:19
What is the most benefitial technological advance ever created? Koko Ed Math and Science 28 05-05-2005 22:52
What is the most obscure technological advance ever created? Allison K Math and Science 4 30-04-2005 15:09
