Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 23-05-2010, 14:58
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Bizarre license issue
So today I started up Windriver after a fairly long period of non-use in order to begin the process of teaching the rookie programmers on my team how to use it. However, instead of starting up, it gave me the message:
Could not set up License Management
Details:
The License-Library was not found, licensing disabled
See the logfile for more information!
The bizarre part of this is that it worked all through build season, and just spontaneously quit without any change in configuration. I have tried re-running the latest Windriver update, to no avail. I don't currently have the installation disks, but is there a way to just reinstall it off the internet or something?
Get yer robot source code here!
Unread 23-05-2010, 18:36
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Re: Bizarre license issue
They have a rather interesting method of licensing, one thing that might be causing the problem is the date, the licence may expire if the date on your computer changed. Or it might be some environmental variables is causing the problem. I had the same thing, and I still couldn't figure it out...
You can start with Eclipse if you want to teach the new programmers...
-Masoug
JabbaScript
Unread 24-05-2010, 00:33
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Perhaps it has lost the liscense file. If you can figure out where it's supposed to go you can copy it from the install CD. Unfortuately, I doubt the legality of one of us posting a copy for you
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Bizarre issues with compressor code Rafael Vasquez Programming 2 10-02-2010 22:26
Bizarre EasyC vex problem -- perpetual autonomous Joe G. Programming 3 22-03-2008 07:54
Bizarre Mecanum Programming Bug manderson5192 Programming 10 08-02-2008 22:11
Bizarre Driving Issue kitscuzz Programming 23 11-02-2007 17:02
Yes, another music license issue..... daniel.thyrso 3D Animation and Competition 0 16-01-2006 14:00
