Go to Post I need a This-Is-What-I-Meant checker. - N7UJJ [more]
Unread 24-05-2010, 17:42
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Question How Many Iterations?
Hi,
How many iterations per second does "Iterative Robot" method do for periodic functions?
Are they constant? Or are they variable?
THANKS!!!
-Masoug
JabbaScript
Unread 24-05-2010, 17:52
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: How Many Iterations?
By default the period is whenever a packet is recieved from the DS (about 50 Hz according to the source).
To define your own period, call SetPeriod(double seconds). FYI this is a minimum. If the code is taking longer than the period to execute, it will wait for the code to finish. Also, call SetPeriod(0.0) to reset it to DS packets.
For # of loops per second, call GetLoopsPerSec() (warning: it doesn't check for the special 0.0 value that signals DS packet sync. It will try to divide by zero if you call it when in DS sync mode)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 24-05-2010, 21:43
masoug's Avatar
Food Consumer
FRC #0114
Coll thanks! But:
do we have to include additional header files and etc?
THANKS!!!
-Masoug
JabbaScript
Unread 25-05-2010, 18:10
AKA: Ian Thompson
Nothing extra is needed. Those functions are inherited with the IterativeRobot class
How many spikes The Ars-sassin Electrical 3 13-02-2010 00:22
People as Support Personnel in the Elims, How many is too many? thefro526 Championship Event 9 02-05-2009 23:09
How many interrupts is too many interrupts? Madison Programming 14 08-02-2008 12:09
How many teams.... archiver 2001 0 24-06-2002 04:03
