Go to Post I am not a moderator, but I am John V-Neun. - Billfred [more]
Unread 23-05-2010, 16:08
Dale's Avatar
Dale Dale is online now
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: 6 wheel drive with chain tensioners and shifting
There are several sources for the 1" nylon inserts if you want to go that way. Mcmaster.com has them. We've been using the 80/20 Quickframe series and so far have never had a failure of an insert. http://www.8020.net/Quick-Frame-5.asp
These are designed to be used with their 1" aluminum box that have little groves inside to to hold in the inserts. We always drive in a sheet metal screw or 10-32 bolt just to make sure they don't come apart. The profiles are at http://www.8020.net/Quick-Frame-4.asp.
Compared to normal 80/20 extrusion it's more of a pain to work with but it's almost exactly half the weight.
Unread 23-05-2010, 18:06
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Frame should easily be in the 10-20lb range. For a complete drivetrain 45lbs isn't great but its also not entirely horrible. You still have a decent amount of weight to play with. It really just depends on what you're going to add on the robot.
Mentor 2415
Unread 23-05-2010, 23:38
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
looks like our frame weighs 22 lbs and the gearboxes/motors/wheels weigh 23 lbs
I like the sound of these, I will suggest them to the other students.
With the women comment, that is just what we have always called our bots, mainly due to the fact that our whole design and fab team is male.... I can see how the comment could easily be misconstrued.
Thanks for all the input guys.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 24-05-2010, 15:16
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
If you want me to, I'll run stress on the CAD. If you want, I'll also see what I can do to strengthen/lighten it.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 24-05-2010, 19:47
Edoc'sil's Avatar
FRC #2531
Actually my mentor showed me how to run the side panels and their supports as a single part, which apparently is a good enough approximation. I will post the files though if anyone wants to look at them.
Unread 24-05-2010, 20:46
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Only if you're up for it. I am interested in seeing the result file though.
AndyMark Chain Tensioners CodyHarris Kit & Additional Hardware 2 28-03-2010 13:29
pic: Integrated, easy to use chain tensioners Jon Stratis Extra Discussion 9 21-02-2010 22:37
pic: Sliding Wheel Chain Tensioners Ice Berg Extra Discussion 18 22-04-2009 00:45
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
