Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
Unread 05-24-2010, 08:54 PM
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: IFI Control System to Wifi?
For the router and bridge to understand the signal from youroperator interface, you'd have to convert it into TCP/IP networking data. A 2009 or 2010 control interface will do this automagically, but an older one based on the IFI OI unit will require a custom-programmed "gateway" to sit between the OI and the router.
The same thing applies in reverse on the robot end. The IFI controller can't understand your TCP/IP encoded signal, so you need another gateway between the bridge and RC to convert the signal back into IFI-format. I'm not entirely sure if the IFI controller needs to handshake with the OI, but if it does(Or if you want to send back any sort of telemetry), both gateways would need to operate bi-directionally.
EDIT:Actually it looks like the Luminary Micro device at least is capable of performing this gateway function That makes it a lot easier if you want to connect a pre-2009 OI to a pre-2009 RC.
Get yer robot source code here!
Have an IFI control system you don't need? hal_2498 Control System 13 05-05-2009 09:45 AM
Using IFI Controller witout Operator System 703pascal Programming 20 06-16-2007 10:10 PM
IFI Control System (OI/RC) - The Future??? ChuckDickerson Control System 56 06-03-2006 08:25 PM
Important IFI Control System Update Kevin Watson Control System 5 02-25-2004 11:31 PM
