Go to Post Wait, crap... totally forgot that I needed to build an intake. :eek: - Andrew Schreiber [more]
Unread 24-05-2010, 21:37
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Yet another 6wd base (would like input please)
I know that there have been a lot of these posted lately, but I would like to post my version of a 6wd skid steer drive base.
Overall- http://i517.photobucket.com/albums/u...obackround.jpg
Electronics- http://i517.photobucket.com/albums/u...ronicsview.jpg
Chain Tensioner- http://i517.photobucket.com/albums/u...sionerview.jpg
This design was based off of what I got to see of 1114's bot in 08. The rest of it is a "best of the best" group of characteristics and building techniques taken from my 3 years of building FIRST robot drives. However through 3 years, we have never used more than 4 wheels.
Specs:
Weight is 49.5 lbs. as pictured minus battery
6: 4" ifi traction wheels with 1/8" drop in the center
4 Cim in toughboxes: We have never shifted before and this is simpler, lighter and cheaper.
Speed is geared at 9.4 fps but can be changed easily through new ratios in the TB or new sprockets after the TB
Frame is 1X1 .125" wall Aluminium tubing.
Long chain is tensioned by sliding a small bolt and nylon spacer complex. (see picture)
Shorter chain is tensioned using an AM floating tensioner.
Electronics board is 1/8" polycarbonate with an aluminum angle support for the battery and 1/4" plate under the compressor.
I would love to get some feedback on potential failures or successes of my design.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 24-05-2010, 21:46
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: Yet another 6wd base (would like input please)
Overall- http://i517.photobucket.com/albums/u...axyoverall.jpg
Specs:
Looks pretty good, but I'm a little concerned with your tensioner. Is it at all possible to make it stretch between the two 1x1's so that it's not under a cantilevered load? You're also going to need to be really careful while welding this together (I assume it's welded), because if you're even a few degrees off it won't line up right.
Side comment:
If you could stick with the normal background while rendering, it makes your design easier to look at.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 24-05-2010, 22:08
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I see some similarities to the KOP chassis, looks proven.
You don't need a 1/4" plate and 1/8" polycarb is still pretty heavy, try some thin stuff with holes in it for zipties. The BG is distracting. The welds don't have to be perfect because those are dead axles as long as your wheel ends up perpendicular to the ground. The chain run concerns me because if you lose the long chain you're out the whole side. The tensioner should work fine.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 24-05-2010, 22:17
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Great looking chassis... Though there is one thing that I have noticed. The placement of the Jaguars worries me a bit because they tend to overheat. Placing them under the already heated CIM's and having them not get the ventilation they need could potentially burn them out. Believe me, I have seen Jag's go. This is just something I picked up on. The Chassis looks great though.
Unread 25-05-2010, 09:38
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Along with the non-cantilevered tensioner, I would recommend using an idler sprocket on a bearing. Using precise spacers, this will help keep the chain inline, and will also lower the resistance of rubbing on a round idler.
Unread 25-05-2010, 11:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
+1 to Ike and 548 Swimmer, your chain tensioner is going to get wrecked!
I would switch the locations of your electronics and battery/compressor, get the battery and compressor nearer to your CG and (hopefully dropped) center axle. This lets you see the lights on the jaguars and sidecar more easily which can be very useful for debugging or trouble-shooting.
I would also lose the lexan and mount everything on a piece of high-quality plywood. You'll probably be able to eliminate all of the 1/4" aluminum plate under there and it will really help your chassis stiffness. It's really easy to mount and re-configure electronics on plywood too.
pic: 6WD base kajeevan Extra Discussion 6 11-08-2009 07:56
Yet another Camera thread... Pancake C/C++ 2 26-01-2009 11:42
Yet another bumper thread Vikesrock Technical Discussion 26 19-01-2009 17:04
yet another programming error hawk_11 Programming 2 13-02-2005 15:57
Yet another website to critique Joshua May Website Design/Showcase 11 18-10-2004 09:18
