Go to Post We talked to a team in Las Vegas and next year there will be another team with a 25 drive train. The west coast may never be the same. - nuggetsyl [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 25-05-2010, 14:22
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: T-Shirt cannon AC problem
Originally Posted by KGood View Post
Our team is trying to make a mounted t-shirt launcher, but we're running into problems with the sprinkler head we're using. We want to mount it to the robot and use the power distribution board but that uses DC, and the sprinkler head requires AC.
So, my question is: If we use 24v of DC from the power distribution board, is there any possible harm that come as a result? The sprinkler head has no circuitry...it's basically just a magnetic release valve, but I wanted to be sure.
Thanks!
Yes there are potential problems. On a project at work we were accidentally supplied 24 VDC valves in place of the 24 VAC valves we ordered, BTW 24 VAC is standard for HVAC applications. They were not caught at recieving inspection. We powered the valves on and all they did was chatter until the seats failed.
You should either use a transformer/inverter to correct the voltage to AC or get a new solenoid. You might be able to purchase and identical DC coil from the manufacturer.
Thank-you 294 & 67
www.bobcatrobotics.org
Robotic T-Shirt Cannon robself705 Robot Showcase 5 13-11-2009 15:33
T-Shirt cannon pnuematic set ups Bryan Herbst Pneumatics 62 21-07-2009 23:16
pic: TEAM 343's t-shirt cannon Josh Drake Extra Discussion 14 20-04-2009 18:58
pic: T-Shirt Cannon at Purdue's Homecoming jtdowney Extra Discussion 10 08-11-2007 19:48
IRI T-shirt cannon Kyle Love Off-Season Events 6 17-07-2007 12:09
