Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 25-05-2010, 19:42
Brent Strysko Brent Strysko is offline
President
AKA: JCODER
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Webmaster
Brent Strysko is an unknown quantity at this point
Programming the Old Controller
Hey Guys,
So Team 1672 is doing an off season project where we are building an arena to do battle vex robots in. We want to use electronics that control relays for lights. Anyway that part is easy. The problem we are having is using the old controller from around 2005/2006 and Kevins Serial Port Code( http://www.kevin.org/frc/ at the bottom of the page) we keep on getting a code error. Have any of you used this code before. If not how could we interface a computer serial port to our controller / OI for data communication.
Thanks
Unread 25-05-2010, 20:33
Re: Programming the Old Controller
Question 1: What version of the compiler, etc., are you running?
Question 2: What is the code error?
A number of people have used the code before, quite successfully.
I would also try contacting the following CD member for assistance (if he doesn't see this thread before someone gets to him):
http://www.chiefdelphi.com/forums/member.php?u=1028
Unread 25-05-2010, 21:10
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
i have also used the code with no problems in the past, some more info would be helpful so someone can help you solve your problem.
Unread 25-05-2010, 21:48
It's important to know if it is a 2005 or a 2006 controller, they have different microprocessors.
If it is a 2005 controller, read the file called Using_Last_Years_FRC included in the zip file.
Eric's question about the compiler version is very relevant, also.
Unread 28-05-2010, 02:44
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Brent Strysko View Post
Hey Guys,
Thanks
As others mentioned, we'll need more information to help you out. My code builds just fine with the latest (3.35) compiler.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-05-2010, 17:04
President
AKA: JCODER
Thanks everyone who has responded so far. Okay well our team is currently working on reorganizing our closet so I am not sure what year the controller is, however I did open it up and see it was a PIC18F8520. So would this mean I have to use the code in the "old directory". That would explain it. I only knew there was an error because the code error LED on the controller would turn on and off.
So interfacing from PORT1 on the OI does not require any special cables besides a standard serial cable?
Unread 28-05-2010, 20:14
FRC #2429
You should be able to to use this code without any problems:
http://kevin.org/frc/ifi_frc_simple.zip
Make sure you use the '8520 linker script and library. I would suggest using the latest release of C18 too.
Yep, that simple. If you're looking for example code that shows how to interface with a user at a termainal and with a computer, have a look at the 2007 CMUcam software:
http://kevin.org/frc/2007/frc_camera_2.zip
-Kevin
Kevin Watson
http://kevin.org
Unread 28-05-2010, 20:41
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
-Kevin
I just realized, you are the kevin from kevin.org... LOL
Unread 29-05-2010, 00:49
FRC #2429
I hope so. If I were the Kevin from kevin.com, I'd be a lawyer in Arizona and probably wouldn't want to hang out here with people who have made better life choices <grin>.
-Kevin
Kevin Watson
http://kevin.org
Playing around with old controller RedSoxFan Programming 1 21-04-2010 18:50
Programming with the 2009 controller slavik262 Programming 97 20-10-2008 21:59
using an old p-basic controller fimmel Control System 5 13-11-2006 23:55
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
Old 883= 24V Speed controller??? stealth13777 Electrical 17 21-07-2005 12:45
