Re: pic: 3 Motor Single Speed Gearbox
You can definitely use the CIM mounting holes as the transmission stand offs. This design overall looks good. You could look into using delrin plates instead of aluminum to drop a bunch of weight for the same amount of machining. Also think about how you are going to mount the transmission as right now there are no mounting holes.
I would not recommend Delrin plates. Holding tolerance is more difficult, and they flex, causing gear wear issues.
Also, assembling the box with the motor bolts is quite doable, but makes assembling a bit of a hand gymnastics exercise. Edit: A bit of a suggestion: If you can recess the standoffs to allow the box to 'snap' together, it makes assembly much easier, and makes aligning parts much quicker. |
Looks really nice thus far. You may want to search cd-media for our 2008 drivetrain. I designed it to be a 6 motor (4 CIM, 2FP) single speed drive system with 4.75" wheels. Just something comparable to look at.
If I am interpreting your question correctly you were asking about clearance inside the gearbox. Be sure you give yourself some clearance for tolerance stack up. If you don't, when you tighten everything up your gearbox could be seized up, or you may even damage your bearings. The motor screws are completely legit to use as a method to hold the gearbox together. Keep up the good work. -Brando |
Why not use a 1/8" plate instead of a 1/4" plate?
One advantage of 1/4" plate here is it lets you put the CIMs real close to each other without the bearing popping through and hitting them.
#7
If you're gonna mill the plates, you're gonna need some exterior fillets. If you're gonna jet them, you're probably fine, but I still like having the fillets there for cosmetic reasons.
Having counterbores for the standoffs certainly keeps everything more ridgid, but i would say makes assembly much more difficult. Lining up every standoff with its corresponding hole can be quite a challenge (which would probably become even harder with these being the motor mount screws). If you're gonna include counterbores for the standoffs, do not do it on all six standoffs. Even with just four counterbored standoffs on our gearboxes this year, it was still quite a challenge to line them all up. Last edited by NickE : 26-05-2010 at 01:51. |
#8
That's pretty much the only reason, and I wanted two identical plates. You can't put 3 CIMs on the gearbox with this ratio without overlapping the bearings.
#9
Also, I wouldn't use the motor mounting holes as the gearbox plate holes, mainly because I like those motor mounts TIGHT and sometimes gearbox assembly bolts need to be loosened a little bit so the gearbox can run with less internal friction. I suppose that may be a personal bias though and not a requirement. One other thing to think about: How would this mount onto the frame of a robot? The machined plates look cool, but how would you mount it? That's probably too much of a robot-specific question to fully answer right now but is worth thinking about. Looks good. Keep up the hard work. |
#10
Since you have 2 stages there Chris, I'd evaluate the gears you have available and try to shoot for center distances between the second gear stage shafts that will allow you to swap out for a couple different gear sets. Much like the final stage on the super-shifters allows you to modify the gearing by swapping 2 gears. This is FAR easier than changing the spur gears on the 3 motor outputs, and will allow you to modify easily should you ever want to drop a FP or CIM and need a slightly different torque.
#11
| pic: Simple single reduction duel CIM gearbox | Lowfategg | Extra Discussion | 11 | 05-10-2009 22:47 |
| White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox | CD47-Bot | Extra Discussion | 9 | 30-08-2004 21:57 |
| pic: 716 single speed | CD47-Bot | Extra Discussion | 2 | 09-09-2003 15:51 |
| Multi Speed Dual Motor Gearbox | tenfour | General Forum | 14 | 08-09-2003 13:09 |
