Go to Post We want to win, but we would prefer to do so with a great partner team, not just a great partner robot. - Zach Purser [more]
Unread 28-05-2010, 00:21
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: pic: aces high drive base concept
Well, first off, the middle wheel will spin in a different direction than the two outer wheels because of the way your chain is right now. I also don't think that chain-run would work (even if you neglected the fact that the middle wheel is spinning in the opposite direction) without any sort of tensioning system. Even then it would have a higher chance of slippage because there isn't adequate chain-wrap.
In my team's past experience, we have always found it difficult to precisely drill holes into 80/20. When trying to offset the holes by 1/8th of an inch (which I am assuming your middle wheel is) the drillbit tended gravitate towards the channels of the 80/20 because it's unlike drilling into a uniformly smooth surface. However, we centered everything manually and used a drill-press.
Unread 28-05-2010, 11:39
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
Team Role: CAD
kinghashbrown is an unknown quantity at this point
I plan on running two chains from the gear box, one chain down to the middle wheel then to the from there to the front wheel, and the second to the back wheel. Since the AM shifter is made to have two sprockets inside of it.
For a tensioner I planned on making something that would mount into the slots on the 80/20 bars and/or spacing the plastic slider up with aluminum spacers and washers.
Drilling shouldn't be a problem. it should be easier to do on a Bridgeport.
Originally Posted by Chris is me View Post
If you weld or drill through 80/20 in this fashion you get pretty much the same weight as 1/8 wall tube and adjustability for whatever you put on top of it. Worked for Shaker this year.
It might be easier to run a Supershifter in the middle.
My team normally has been able to weld our robots. however we don't think that we will be able to have welding done this fall.
I know I could use Supershifters and it may be easier. However I wanted to explore other ideas.
pic: Aces High 176 Breakaway Bot AcesJames Extra Discussion 10 07-03-2010 22:05
Aces High on Ice BobC General Forum 9 04-02-2008 09:36
pic: Aces High 176 testing drive BobC Extra Discussion 6 27-01-2007 19:39
Aces High Raffle BobC General Forum 20 08-12-2006 08:09
pic: This is Pokerface from ACES HIGH 176 desi_technology Extra Discussion 1 21-03-2006 15:47
