Go to Post Leave it to Cheif Delphi to make a thread go from discussing the imminent game hint to discussing what is the superior pizza topping. - BriteBacon [more]
Unread 28-05-2010, 16:07
ZipTie3182's Avatar
ZipTie3182 ZipTie3182 is offline
AKA: Anna Sklenar
FRC #3182 (Athena's Warriors)
ZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the rough
Smile Chain driven vs Direct drive mechanum
Hey, our team completed our rookie season but are looking to fix up our robot this summer for off season competition this fall. We are interesting in adding mechanum wheels and we want to try them out when we have plenty of time. However, we're not really sure what the pros and cons of chain driven and direct drive systems are. So, if you could enlighten us a little bit, that would be awesome. Also, a list of parts would we need for each would also be super helpful. Thanks!!
Unread 28-05-2010, 16:13
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Chain driven vs Direct drive mechanum
Pro's of Direct Drive
1. Less components
2. Lighter Weight
3. No chain tensioners to worry about
Con's
1. If you don't know the exact drive ratio you want for the bot, it's harder to adjust speeds with direct drive.
2. You're locked in to putting your transmissions at the 4 corners of the robot. (This year that would have been bad - you would have really limited your space for the ball and your kicker.
3. Servicing can be difficult if you aren't carefull with the design with direct drive.
In your case, if this is a learning situation, I'd definitely say go with chain driven so you can play with your drive ratios until you're happy.
Unread 28-05-2010, 16:19
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Tom Line is right on the money for a development robot.
If i knew the gearing I wanted for a competition 'bot I'd go with direct drive (if at all practical) just to not have to deal with chains, designing tensioning systems, and the keys/set-screws generally associated with sprockets. We used a chain-driven mecanum driveline this year, it was not hassle-free.
Unread 28-05-2010, 23:10
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Since nobody has said anything about chain-drive:
Pros:
easy to get
very resistant to shock loading
Very reliable when done right (notice the qualifier please)
Cons:
can take up large volumes within the robot
can be unreliable if not done right
can be heavy
Christopher H Husmann, PE
"Who is John Galt?"
Unread 29-05-2010, 00:52
Chris is me's Avatar
AKA: Pinecone
Direct drive has the pros of less weight and you don't have to deal with roller chain, which is really really annoying in my experience. The cons are mainly packaging, if you don't like where direct driving makes you put your gearboxes you shouldn't use it. You also have more trouble changing your gear ratio if need be.
Chain drive has the pro of letting you put your gearboxes in the center of your robot and quick reduction adjustments with different sprockets, with the con of a lot more weight, and dealing with the tensioning hassles of roller chain.
If I remember you guys from CT correctly you'll need to add two more gearboxes to your robot either way.
Unread 29-05-2010, 16:01
ttldomination's Avatar
Sunny
Well, for issue one. I would recommend a AM SuperShifter. The shifters themselves offer lots of options when it comes to switching out gears and playing with different ratios.
As for the second issue, this is assuming you have a 4 WD. I've seen many teams place their direct drive gearboxes right smack dab in the middle of their 6WD, and they get stellar results.
The general preference in a 6WD is that one of the wheels is direct driven, and then the other wheels are either chained or belted together. Either way, you'll need 8 sprockets/pulleys total (if you go DD) and still a decent amount of chain/belting.
But, Direct Drives do require precision. Gearboxes must be properly integrated into the chassis in order to get the appropriate height off the ground/ample support for the output shafts.
- Sunny
1648: 2013-2014
5283: 2015
Unread 29-05-2010, 16:49
Mecanum drivebases with anything besides four wheels are rare, to say the least.
Unread 29-05-2010, 19:24
Sunny
Oh, I wasn't aware we were speaking strictly in mecanum drive train.
1648: 2013-2014
5283: 2015
Unread 29-05-2010, 20:11
hg273's Avatar
hg273 hg273 is offline
AKA: Henry Gordon
FRC #1540 (Flaming Chickens)
hg273 will become famous soon enough
I'd recommend against Supershifters. For the competitions, if you are driving a mecanum base, you won't be winning any pushing battles. Having a shifting system won't help you there. In terms of being able to play with different ratios, Shifters would only allow you to try two. It's almost better just to make your base in a way that it's not impossible to change out the sprockets.
For a first time mecanum base, I'd recommend chain drive. Because this won't be a competition bot, you don't have to worry about the weight or the volume, and chain will give you numerous benefits as you experiment.
That said, depending on the challenge next year, you'll most likely want to reevaluate your options should you choose to go with mecanum drive.
Unread 03-06-2010, 21:09
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Can't the drive ratio thing just be solved by the software? Just reduce the maximum PWM output
Unread 03-06-2010, 21:12
Nope, that just reduces the speed. The drive ratio changes the available speed and torque at the wheel, which affects other things.
Change PWM==change speed only, which is how you drive anyway.
Change gear ratio == change available torque and available speed.
Unread 03-06-2010, 21:13
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
If you fix it in software, you reduce the torque (pushing/accelerating power) necessary. If you have trouble steering straight, you CAN fix that in software. While a mecanum does not need pushing power that much, since the wheels slip, it has to accelerate.
Edit: Eric beat me to it.
Kettering Motorsports
Unread 03-06-2010, 21:17
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
LOL This is why I am a programmer, not a hardware guy
Unread 04-06-2010, 00:18
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
This is my first year on Team 2410 and we used a chain-based mecanum drive. From what I saw, here's some specs on it:
Pros:
Easy to set up
Easy to fix
Gave us a lot of experimentation room as far as where the gear boxes went
More space for the edges of our robot
Cons:
Chain is like a woman. High maintenance XD
Chain would get caught on various things
Needed grease every so often
Sometimes would fall off if not tuned exactly
So that's what I picked up on and could pull off the top of my head. I don't believe we ever tried a direct drive mecanum so I can't help on that. Hope my 2cents helps.
Unread 04-06-2010, 00:36
Tom Line's Avatar
A correctly set-up chain drive should require zero maintenance. We use 25 chain and didn't have a single break or issue, nor did we ever have to adjust it.
The trick is to hand grind (or cnc your chassis) so that you have good alignment.
The other trick is to develop a tensioning system that doesn't add friction, and keeps the chain snug. Snug, not TIGHT. Tight chain is bad. Snug chain with just a hint of play is perfect.
Our 8 wheel traction drive train had more problems with the plaction wheel fasteners working free then breaking off. We were using grade 8 fasteners and locknuts. A bit too much forward and back working I guess.
I wonder if it would be a good idea for andy mark to put 8 more holes on their chain sprockets and 8 nubs on their wheels so the two 'key' together.
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
easyC Mechanum Drive Code Kingofl337 Programming 0 12-01-2007 23:48
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 05-06-2005 12:19
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
