Go to Post Hopefully LMFAO will cross paths with FRC71. They've been shufflin' since 2002. - Taylor [more]
Unread 28-05-2010, 20:14
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Programming the Old Controller
Originally Posted by Brent Strysko View Post
So would this mean I have to use the code in the "old directory".
You should be able to to use this code without any problems:
http://kevin.org/frc/ifi_frc_simple.zip
Make sure you use the '8520 linker script and library. I would suggest using the latest release of C18 too.
So interfacing from PORT1 on the OI does not require any special cables besides a standard serial cable?
Yep, that simple. If you're looking for example code that shows how to interface with a user at a termainal and with a computer, have a look at the 2007 CMUcam software:
http://kevin.org/frc/2007/frc_camera_2.zip
-Kevin
Kevin Watson
http://kevin.org
Playing around with old controller RedSoxFan Programming 1 21-04-2010 18:50
Programming with the 2009 controller slavik262 Programming 97 20-10-2008 21:59
using an old p-basic controller fimmel Control System 5 13-11-2006 23:55
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
Old 883= 24V Speed controller??? stealth13777 Electrical 17 21-07-2005 12:45
