Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Unread 29-05-2010, 16:01
ttldomination's Avatar
Sunny
Re: Chain driven vs Direct drive mechanum
Originally Posted by Tom Line View Post
1. If you don't know the exact drive ratio you want for the bot, it's harder to adjust speeds with direct drive.
2. You're locked in to putting your transmissions at the 4 corners of the robot. (This year that would have been bad - you would have really limited your space for the ball and your kicker.
Well, for issue one. I would recommend a AM SuperShifter. The shifters themselves offer lots of options when it comes to switching out gears and playing with different ratios.
As for the second issue, this is assuming you have a 4 WD. I've seen many teams place their direct drive gearboxes right smack dab in the middle of their 6WD, and they get stellar results.
The general preference in a 6WD is that one of the wheels is direct driven, and then the other wheels are either chained or belted together. Either way, you'll need 8 sprockets/pulleys total (if you go DD) and still a decent amount of chain/belting.
But, Direct Drives do require precision. Gearboxes must be properly integrated into the chassis in order to get the appropriate height off the ground/ample support for the output shafts.
- Sunny
1648: 2013-2014
5283: 2015
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
easyC Mechanum Drive Code Kingofl337 Programming 0 12-01-2007 23:48
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 05-06-2005 12:19
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
