Go to Post FIRST is an addiction but at least it is one of the healthiest addictions you can have (if you wear your safety goggles!). - Pavan Dave [more]
Unread 31-05-2010, 01:05
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Refnum like interface for CANJaguars
*Note that I have not tested this yet*
After playing around with Labview a little bit, I learned that I liked the idea of Refnums (identifier strings that can be used to describe and identify objects).
And after using Java and CAN on this years robot, I wanted something that would not use the bus for every single call to the getter methods.
So, I made a simple class that uses a Hashtable (Stores the instances of CANJaguar with a unique and descriptive name (like a refnum)) and a TimerTask that updates the data in the local cache at around 50 hertz.
Here is a simple example that uses the class (a simple arcade drive teleoperated)
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.CAN.CANBus;
import edu.wpi.first.wpilibj.IterativeRobot;
public class RobotTemplate extends IterativeRobot {
    CANBus bus = new CANBus();
    Joystick arcade = new Joystick(1);
    public void robotInit()
        bus.addJaguar("LeftDrive", 2);
        bus.addJaguar("RightDrive", 3);
    public void autonomousPeriodic() {
    public void teleopPeriodic() {
        // Arcade drive implementation
        double speed = -arcade.getY();
        double turn  = arcade.getX();
        double left = speed + turn;
        double right = speed - turn;
        if(left > 1){ left = 1;}
        else if(left < -1){ left = -1;}
        if(right > 1){ right = 1;}
        else if(right < -1){ right = -1;}
        // End arcade drive implementation
        bus.setPercentOutputVoltage("LeftDrive", left);
        bus.setPercentOutputVoltage("RightDrive", right);
and here is the actual class (Note that I made a slight change to the JaguarCANProtocol class, I added
public static final int LM_STATUS_FAULT_BUSERR = 0xFF;
so that I could signal to the main execution loop that there was an error in either transmission or reception.):
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package edu.wpi.first.wpilibj.CAN;
import java.util.Timer;
import edu.wpi.first.wpilibj.util.UncleanStatusException;
import java.util.Enumeration;
import java.util.Hashtable;
import java.util.TimerTask;
 * Keeps track of all CANJaguar instances on CAN bus using unique Names.
 * Use this to access information about a jaguar without acessing the bus directly
 * This is a local cache so that data from the bus is not accessed except by one thread.
 * Will update the data around 50 times a second depending on the # of devices
 *  on the bus, and on the device used to cummunocate with the Jaguars (ie 2CAN or black jag)
 * As far as controlling the JAguar goes, this only supports the Voltage control mode (for now)
 * If other modes are needed, then use the getjaguar method.
 * (Note that controlling the jaguar outside of this class will not provide any exception handling)
 * @author biojae
public class CANBus
    // Keep an instance of each CANJaguar, (Generics not supported by squawk)
    private Hashtable devices = new Hashtable();
    // Keep a local copy of status information on each jaguar so as to reduce data throughput on CAN
    private Hashtable statuses = new Hashtable();
    //Update the device information ~50 times a second (depending on # of devices)
    private Timer updateThread;
    public CANBus()
        TimerTask update = new TimerTask()
            public void run()
                for (Enumeration name = devices.keys() ; name.hasMoreElements() ;)
                    String jagName = name.nextElement().toString();
                    CANJaguar currentJag = (CANJaguar) devices.get(jagName);
                    CANJaguarInfo currentInfo = (CANJaguarInfo) statuses.get(jagName);
                    try{
                        currentJag.set(currentInfo.outputPercentVoltage);
                        currentInfo.BusVoltage = currentJag.getBusVoltage();
                        currentInfo.OutVoltage = currentJag.getOutputVoltage();
                        currentInfo.Temperature = currentJag.getTemperature();
                        currentInfo.outCurrent = currentJag.getOutputCurrent();
                        currentInfo.position = currentJag.getPosition();
                        currentInfo.speed = currentJag.getSpeed();
                        currentInfo.faults = currentJag.getFaults();
                    }catch(UncleanStatusException errorOnBus)
                        errorOnBus.printStackTrace();
                        currentInfo.faults = JaguarCANProtocol.LM_STATUS_FAULT_BUSERR;
                    statuses.put(jagName, currentInfo);
       updateThread = new Timer();
       updateThread.scheduleAtFixedRate(update, 0, 20);
    public void setPercentOutputVoltage(String name, double set)
        if(statuses.contains(name))
            ((CANJaguarInfo)statuses.get(name)).outputPercentVoltage = set;
    public boolean addJaguar(String name, int ID)
        try{
            devices.put(name, new CANJaguar(ID));
            statuses.put(name, new CANJaguarInfo());
        }catch(UncleanStatusException CANBusError)
            devices.remove(name);
            statuses.remove(name);
            CANBusError.printStackTrace();
            return false;
        return true;
    public double getTemperature(String name)
        if(devices.contains(name))
            return ((CANJaguarInfo)statuses.get(name)).Temperature;
        return -1;
    public double getBusVoltage(String name)
            return ((CANJaguarInfo)statuses.get(name)).BusVoltage;
        return -1;
    public double getOutputVoltage(String name)
            return ((CANJaguarInfo)statuses.get(name)).OutVoltage;
        return -1;
    public double getOutpuCurrent(String name)
            return ((CANJaguarInfo)statuses.get(name)).outCurrent;
        return -1;
    public double getPosition(String name)
            return ((CANJaguarInfo)statuses.get(name)).position;
        return -1;
    public double getSpeed(String name)
            return ((CANJaguarInfo)statuses.get(name)).speed;
        return -1;
    public short getFaults(String name)
            return ((CANJaguarInfo)statuses.get(name)).faults;
        return -1;
    public CANJaguar getJaguar(String name)
            return (CANJaguar) devices.get(name);
        return null;
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
ADXL345 SPI Accelerometer set/get Refnum Jon236 NI LabVIEW 3 16-02-2010 10:20
Watchdog/Refnum/Labview Problems weinbergmath NI LabVIEW 2 13-02-2010 11:24
Problems with RefNum Registry get vi zebrabots NI LabVIEW 3 02-02-2010 22:16
Refnum Defining Pausert NI LabVIEW 15 21-01-2010 21:45
refnum registry location Wendy Holladay NI LabVIEW 1 17-01-2010 22:11
