Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 28-05-2010, 17:39
phil-1302's Avatar
phil-1302 phil-1302 is offline
AKA: Phil
FRC #1302 (Revolution Robotics)
Team Role: Driver
phil-1302 will become famous soon enough
Programming the 2009 Control system (cRIO image)
Well, my team has an off season robot that we use for charity events, school events, etc. We were using the 2005 control system for the robot until a series of unfortunate events leading to the use of a fire extinguisher on the robot happened . We still have the Control system from 2009 (lunacy) and a spare cRIO, which was used for program testing this past season. We have the program built, but we cannot find the image for the cRIO for the past 2009 season.
Any help would be greatly appreciated!!
Phil S
Team 1302
Pope John XXIII Regional High School
Unread 28-05-2010, 18:25
Re: Programming the 2009 Control system (cRIO image)
Phil -
Your best bet is to treat the cRIO like its from 2010 (format it as such), and just use a spare netbook/laptop as the driver station.
Unread 28-05-2010, 20:11
phil-1302's Avatar
AKA: Phil
Team Role: Driver
Originally Posted by EricVanWyk View Post
Phil -
OK! Great! We will try that.
Thanks
Phil S
Team 1302
Unread 29-05-2010, 14:05
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Also, you could consider using this if you really are interested in using the 2009 system
just my .02
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 30-05-2010, 00:03
Just to clarify, the DS for 2009 and 2010 are compatible. The 2010 one has a few additional features, primarily extended I/O, but other 2009 soft DSes or the blue box will work fine with a 2010 image and tools except that the robot that reads extended I/O will never receive it from an 09 DS.
Greg McKaskle
Unread 31-05-2010, 23:44
phil-1302's Avatar
AKA: Phil
Team Role: Driver
GREAT! thanks guys!
Phil S
Team 1302
Tips for C++ programming the 2010 control system woodk C/C++ 12 23-01-2010 21:38
The 2009 Control System Q&A Thread crake FRC Control System 59 11-01-2009 10:43
purchasing buying the 2009 NI cRIO control system martin417 FRC Control System 10 29-12-2008 12:31
Buying the 2009 control system BornaE FRC Control System 9 16-10-2008 17:16
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
