Go to Post Most people who say "winning doesn't matter" have not won enough to have a balanced opinion on the issue. - T^2 [more]
Unread 17-05-2010, 07:26
GaryVoshol's Avatar
Cogito ergo arbitro
paper: MARC 2010 Rule Changes
Thread created automatically to discuss a document in CD-Media.
MARC 2010 Rule Changes by GaryVoshol
Unread 17-05-2010, 09:22
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Re: paper: MARC 2010 Rule Changes
Just to make it easier on refs, would it be possible to have the field clock count up to 10 after the match ends? Also, i take it the standings will be viewable just like the regular season?
Unread 17-05-2010, 10:13
GaryVoshol's Avatar
Cogito ergo arbitro
There is a clock on the field that counts to 10 after the final buzzer. Kind of a hidden feature - they didn't even tell the refs about it until Week 2 or 3. But that's how we knew when 469 was "done".
(since 2004)
Unread 17-05-2010, 15:05
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
It's not a secret either. There is an amber light on the scoring control box above the middle driver's station. Normally the light is OFF.
The light turns ON for 10 seconds at the end of a match (when the buzzer sounds). When the light turns OFF then the scoring controller stops counting.
Also, the light will blink/flash during a match when DOGMA has assessed a penalty for that side (Red or Blue).
Some teams knew about it, some didn't, which is maybe an unfair advantage. If you can see that the other side got a DOGMA (which is not counted in "real time" total on the audience screen, btw) then it might make a difference in your strategy...
Unread 17-05-2010, 18:09
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
G44> BALL CARRYING
There will be no penalty for carrying a ball so slightly above the floor that a referee must take extraordinary measures to see it.
So - you're saying there will be no extraordinary refeering at MARC?
This message is hidden because Jack Jones is on your ignore list.
Unread 17-05-2010, 23:02
GaryVoshol's Avatar
Cogito ergo arbitro
We will extraordinarily referee the other 46 penalties and cards.
And of course, give extra attention to the mentor matches. Can I nominate Jack to be working the trident on an alliance with 469? Dan K has to push the buttons working the flipper lever, and do any pushups for violating <G45>.
(since 2004)
Unread 19-05-2010, 18:41
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
+1. Of course.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 25-05-2010, 15:08
GaryVoshol's Avatar
Cogito ergo arbitro
A technical correction: In one of the revisions, I mixed up the terms NORMAL CONFIGURATION and FINALE CONFIGURATION. That is now fixed - thanks, ExTexan.
(since 2004)
Unread 01-06-2010, 10:50
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Will there be a change to the tournament ranking system, or will it use the standard system after update 16?
Unread 01-06-2010, 15:20
GaryVoshol's Avatar
Cogito ergo arbitro
In the other MARC thread, Steve said the decision was made to stay with the standard seeding. W-T-L does not accurately rank teams any better than cooperition points. A 12-10 win should count more than a 2-0 win. The concern was whether to tweak the coopertition points or not, to avoid 6v0; make a 6-3 win better than a 0-22 loss. Other schemes could make 6v0 less beneficial, but not remove the advantage entirely; under certain situations it would always be better score for the opponents regardless of the seeding scheme. So it was decided to leave things as they were, after Team Update 16.
(since 2004)
Unread 02-06-2010, 20:42
fuzzy1718 fuzzy1718 is offline
MTU class of '15
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
Does this scenario fall under the last rule change?
A robot with a ball in a pincher roller traverses the bump and the ball looses contact with the ground.
My gut says penalty, but I'm not sure.
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
Unread 02-06-2010, 22:52
GaryVoshol's Avatar
Cogito ergo arbitro
That's still a penalty. It would only not be a penalty if the loss of contact with the ground/bump was so slight that it would be nearly impossible to see. No "gotcha's".
(since 2004)
MARC 2010 IS OPEN Steve Ketron General Forum 142 30-06-2010 00:59
MARC 2010 Update #3 Steve Ketron General Forum 12 24-06-2010 13:44
Rule change suggestions for MARC 2010 GaryVoshol General Forum 50 17-05-2010 07:28
paper: 2007 MARC Volunteer Needs Overview KTorak Extra Discussion 3 03-05-2007 06:54
Rule Changes? archiver 1999 6 23-06-2002 22:15
