Go to Post Wow! Can I be wrong too? Please! - dlavery [more]
Unread 20-05-2010, 13:21
JohnFogarty's Avatar
AKA: @doctorfogarty
FTC Prototype Board IR Break Beam.
So I was wondering if it was possible to make a custom sensor using the prototype board that is like a detector beam. Where when an object is in the line of the beam the signal is tripped, I know this is simple but how do you do it?
John Fogarty
Unread 01-06-2010, 23:53
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: FTC Prototype Board IR Break Beam.
our team just got a IR LED thing and a IR detector and lined them up, if the IR detector is not detecting, then the thing is tripped.
Unread 02-06-2010, 00:34
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Yes, it is possible to build an IR break beam sensor with the protoboard.
But, there are 2 reasons why it would be illegal for Hot Shot! :
1. The Q&A response for using LEDs as a sensor
Originally Posted by FTC Q&A
A: <R5>d.8 specifically limits LED's to be used only for signaling to the drive team or for decorations. Homebrew light sensors using LED light sources do not fit within the allowed usages of LEDs and are therefore not allowed.
2. The rule restricting it to visible light only
Originally Posted by FTC Rules
<R5> d.8 8. Only visible light LEDs may be connected to the Prototype Board. These visible LEDs may only be used as a cueing signal for the team or for decoration. If used, the purpose must be demonstrated during inspection.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
[FTC]: Chain Break Andrew Remmers FIRST Tech Challenge 2 18-10-2009 11:34
Break Out Board??? Betty_Krocker FRC Control System 6 10-02-2009 10:26
pic: New FTC robots prototype N7UJJ Extra Discussion 13 09-07-2008 16:02
pic: FTC 35's prototype for 2007 wilsonmw04 Extra Discussion 2 08-11-2007 18:38
pic: 1382 Brazil Prototype + Electronic Board tribotec_ca88 Extra Discussion 1 29-01-2005 15:54
