Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 02-06-2010, 23:26
Chris is me's Avatar
AKA: Pinecone
Re: Toughbox Torque
Originally Posted by theprgramerdude View Post
With my potential design plan I'm looking at, power can only be transmitted in one direction. Reverse the motor direction would do nothing to turn the drive shaft, like on a bike. Only goes forwards, not backwards. Actually, a bike is exactly what I'm looking at. It has 21 speeds to choose from, and the only problem is modifying it to work in reverse as well.
Again, why?
Once you become traction limited, you're pretty much done torque wise. Every gear lower than that just decreases current draw. When you get higher, you get incrementally worse acceleration and greater current draw for incrementally more speed.
Maybe a better track to start on is what about a two speed transmission leaves you unsatisfied? Top speed too low? Not traction limited at the low speed? Want another gear for smoother acceleration?
Toughbox stall torque Galum Motors 4 04-02-2010 15:47
Toughbox Gearboxes GillSt.Bernards General Forum 13 04-02-2009 20:49
Toughbox mounts Adama Inventor 6 28-01-2009 13:54
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
