Go to Post A team isn't who funds it. A team is the people who are on it -Kelli - KelliV [more]
Unread 03-06-2010, 01:45
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Repair of 2007 Victor 884
Originally Posted by sanddrag View Post
Has anyone actually successfully repaired one? It seems there are large copper busses in the middle of the board, which sink all the heat away when trying to clear the through-holes. After giving this a try, I now know why IFI doesn't bother repairing any.
Take a look at this http://www.chiefdelphi.com/forums/sh...4&postcount=31
What replacement FETs did you decide on?
Unread 03-06-2010, 08:18
Sandy,
It depends on the damage. If just one FET or two are bad, the cost to replace probably justifies the repair. Common thinking is that anything beyond a simple FET failure has likely stressed other components to the point of being unreliable in the future.
I have had success with larger Weller tips using Mike Betts' method. However, I heat only the pin and remove it when the solder melts. Then I clean the hole using solder sucker rather than the wick. If one of the holes is still clogged, then I simply heat the new transistor pin as I insert it.
Victor 884 Issues BHS Bucs Electrical 3 01-02-2008 15:10
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
