Go to Post I think all we need now is Jenny Craig for Robots. - ErichKeane [more]
Unread 03-06-2010, 12:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Finding Distance From Driver Station
Originally Posted by Don Rotolo View Post
Hand each of your alliance partners a battery-powered flashing LED, each with a different blink pattern.
(Not to pick on you specifically, several people mentioned similar ideas)
Originally Posted by lineskier View Post
My goal is to do it in such a way that it would be legal, most specifically with R58.
I know lights are low-tech, but this would still be deemed "wireless communication" which is prohibited in R58 because your robot is receiving information from a device not through wires. There is also the logistical problem that your allies might not (or might not be able to) put the lights right where you want them. I really like the "triangulate based on lights" approach, but you'll have to do it using field lights both for the sake of consistency and legality.
Unread 03-06-2010, 15:25
I think this could be a very interesting exercise in deep reading the rules.
Design a system, and ignore the rules for the moment. Make certain that all teams can use your system at the same time. Think about what percent of teams it would be accessible to. Then, look at what rules would need to change to allow the system, and what type of impact that would have on the big picture.
Unread 04-06-2010, 00:17
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Originally Posted by 548swimmer View Post
Have you considered trying a sonar sensor to find your distance?
That might not have a narrow enough beam though.
Partially beam size, partially signal loss over distance (these two are related) cause most hobby sonar sensors I've used have an effective range of about 15 ft; I've seen models advertised with greater range, but this is my experience. You also have the problem that with just a distance sensor, you can't tell what you're measuring, so it would be impossible to know whether you're measuring the distance to a field element, another robot, or a game piece. Distance sensors are very useful for measuring proximity, for example, but for ubiquitous absolute positioning on a FIRST field, it seems like you wouldn't have the kind of accuracy I would want. IMHO.
--Ryan
FRC 766, 2015-, Mentor
Unread 05-06-2010, 14:48
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
--Ryan
Exactly, my goal is to have a solution that works similar to the NorthStar localization. The idea is that you can identify a beacon, and then determine your position relative to it. Given to NorthStar requires a ceiling, but the idea is still the same.
http://www.evolution.com/products/northstar/
Digital I/O from driver station vs FirstTouch I/O Module meakerb FRC Control System 4 05-03-2010 23:06
using digital inputs from the driver station SL8 NI LabVIEW 2 04-02-2009 15:53
Programming Digital Inputs from Driver Station spooncwru Programming 8 01-02-2009 13:14
LabVIEW - Analog inputs from driver station lag? RedOctober45 NI LabVIEW 1 30-01-2009 10:39
Problem Downloading Program from WindRiver to Driver Station The_Laughing_ManMII C/C++ 10 09-01-2009 20:03
