Go to Post The first law of programming is that there are always ways of doing things quicker and in less space than you already are. - jgannon [more]
Unread 03-06-2010, 14:57
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Communicating With A PC
what are you trying to transfer? If you just want to get feedback or basic debug info, you could just use my ZomB Dashboard: http://firstforge.wpi.edu/sf/projects/zombdashboard
it (currently) uses the dashboard packets to send ints, floats, and strings, and also supports the video stream. You can also configure the DS to send data (minus video) to a remote computer (its in a draft manual on the site)
It uses the Dashboard class and works with Java and C++ If you need help, pm me.
Watchdog.Kill();
Driver's Station not communicating with cRio Alexandstein Technical Discussion 8 21-01-2010 21:05
Communicating with a laptop BEEKMAN C/C++ 16 09-01-2010 21:08
Help: IFI loader not communicating with control unit red_alert_13 Programming 9 20-01-2006 17:30
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
