Go to Post My most distinct memory was watching Tom fix our robot's frame... by whacking it with the hammer. - Jaine Perotti [more]
Unread 03-06-2010, 18:11
Chris is me's Avatar
AKA: Pinecone
Re: Toughbox Torque
Originally Posted by theprgramerdude View Post
The trouble is getting to the point where it's traction limited. This could be around 150 to possibly even 200 pounds of tractive force with the right gripping setup. Even with 4 motors, it'll be difficult to get a usable top speed once it's geared down all the way. Furthermore, a second gear with a higher top speed for this would probably create a useless power well, and would have to be tested for optimization (calculus would come into play and simplify things here, but considering that only about 10% of my school takes a beginning calculus course, it's out of the question). Last, the normal two-speed shifters are simply too expensive for us, and would also require pneumatics, something we've began to abhore due to it's weight and volume requirements.
Traction limited with the most common tread material drawing 40 amps of current can get you to about 4-5 fps. Not fast but a reasonable speed for a shifter.
Making a 21 speed drive train with a mechanical reversing secondary gearbox is going to be much, much, harder than fundraising the $800 or so two shifters and extras would cost, for almost zero benefit.
Toughbox stall torque Galum Motors 4 04-02-2010 15:47
Toughbox Gearboxes GillSt.Bernards General Forum 13 04-02-2009 20:49
Toughbox mounts Adama Inventor 6 28-01-2009 13:54
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
