Go to Post And - I would never ever underestimate a rookie. Ever. - JaneYoung [more]
Unread 03-06-2010, 21:17
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Chain driven vs Direct drive mechanum
Nope, that just reduces the speed. The drive ratio changes the available speed and torque at the wheel, which affects other things.
Change PWM==change speed only, which is how you drive anyway.
Change gear ratio == change available torque and available speed.
Originally Posted by apalrd View Post
If you fix it in software, you reduce the torque (pushing/accelerating power) necessary. If you have trouble steering straight, you CAN fix that in software. While a mecanum does not need pushing power that much, since the wheels slip, it has to accelerate.
Edit: Eric beat me to it.
LOL This is why I am a programmer, not a hardware guy
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
easyC Mechanum Drive Code Kingofl337 Programming 0 12-01-2007 23:48
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 05-06-2005 12:19
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
