Go to Post Life is so much better when you do what you love rather than what others want you to do. - KelliV [more]
Unread 03-06-2010, 21:21
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
specs for a "good" progamming laptop
Our old programming laptop burned up (quite literally. A fan broke) and now one of our sponsors is donating a new one to us. I have most of the stuff figured out that we need on the new one (USB ports, wireless card, coffee dispenser, etc) but I'm unsure about what kind of CPU and RAM would be good to run the FIRST software. Any suggestions would be appreciated
Using Windriver C++ and occasionally LabVIEW
One more question primarily directed at NI/FIRST: How do the development tools run on Vista/7 and are there plans to make 7 the officially supported OS in the near future?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 03-06-2010, 21:25
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: specs for a "good" progamming laptop
Just a $300 dell laptop will do, if the crappy class mate can do it, any computer can (serious)
Unread 03-06-2010, 21:29
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
I wouldn't ever try any serious programming on a netbook like the Classmate. You'll want to kill yourself during build season with it, I assure you.
For a programming dedicated laptop, I'd recommend something with a good screen size, but nothing huge so that it's not easy to take to the pits to work with. Something around 15" should do well. Also, you don't need anything extremely powerful, because most programming environments aren't too taxing. The standard 4gb of RAM and a decent dual core processor should do just fine for a newer machine. Intel's new mobile i5 chips are very nice, especially because of their power and efficiency, giving you quite a bit more battery life in a pinch.
What exactly is your "budget" per say?
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 03-06-2010, 21:30
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You can code C++ on just about anything.
Same with LabVIEW. It even runs on that little Atom in the Classmate (it runs quite well, although the screen is too small to fit the splash screen)
I use a Dell with a dual-core CORE2, somewhere around 2ghz per core, with 2gb RAM and a nVidia GeForce GO 7900, but that is powerful enough to do CAD and play 3d games. I also have a very old laptop I used to use for IFI Dashboard, because it had a serial port, and it was from like 1999 and had like a 400mhz processor, I made it run XP, it ran IFI Loader and IFI Dashboard. I always developed on my normal laptop, so I never tried MPLAB.
The point is that any modern laptop can handle coding. Actually, just about any laptop that still is in decent condition will handle C++, and almost
Edit: 2 others beat me to it.
Also, I have a 17" 1920x1200 screen, it really comes in handy with large VI's. It unfortunately does not fit in the designated space for the programming laptop on our robot cart, but I just set it under the robot or on top of the robot or carry it if it must go out with the robot, which isn't often.
Kettering Motorsports
Unread 03-06-2010, 21:36
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If you are budget minded, a pentium m that you'll find in any number of given Dells on ebay coming back from corporate leases works just fine. You'll pay about $200.
Here's a link of just one, as an example:
http://cgi.ebay.com/1-DELL-LATITUDE-... em2307986d2e
or a low end core duo:
http://cgi.ebay.com/DELL-LATITUDE-LA... em45f340a008
Watch and only bid on the lower-priced ones. I came away with a 1.6 for $180 a couple months ago.
Edit: On another note, I just picked something with a bit more horsepower (a ridiculous amount for what you want) for a reasonable price after $250 off:
http://www.officedepot.com/a/product...41-Widescreen/
Unread 03-06-2010, 21:55
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I program other things, like PLCs, Smart Servos, HMIs, Vision Systems, and robot controllers, etc..
And one thing looking BEYOND "FIRST" you may consider is having a laptop with a serial port. I have only found a few laptops right now that can be purchased with a serial port, but even so more a problem is a laptop with a decent OS like Windows XP. I did find one recently that I just bought. Has Windows XP Pro and a Serial Port. I am pretty happy with it so far. I don't like the d-pad mouse buttons, but I run an external mouse always with a laptop anyways.
http://www.toshibadirect.com/td/b2c/pdet.to?poid=464436
I would also recommend the Dell Precision series. Like an M4300 or so. The problem with those now are they too as well are starting to be preloaded with Windows 7 which doesn't normally play nice when trying to write code in ladder logic DOS software or some other compilers like even IFI loader. Windows XP seems to play nice with all the development software packages I have played with.
Dell Outlet has some great deals on some Dell Precision laptops that still have Windows XP loaded.
http://outlet.us.dell.com/ARBOnlineS...=28&l=en&s=dfb
You may not find a serial port on these machines anymore, but for what you want to program now, you won't need it. But if your a hard core junky like me that plays with all different types of hardware, having a native serial port is a blessing.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 03-06-2010, 22:02
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
From experience, a netbook will work for programming (for both LabVIEW and C++). You need to be careful of a few things when looking into a netbook. When programming LabVIEW on my ASUS Netbook (10.1 in. screen) I have to scale up the resolution to get the vision assistant up, and the window doesn't fit well into the screen. I haven't done any C++ on it (since I don't program C++), but when I program Python or other languages, I notice that my hands are VERY awkward on the small keyboard. Especially when reaching for something like a shift key.
With that in mind, I would recommend a regular size laptop. You'll pay less for a laptop for the same specs your netbook would have. Our programmer programmed on a very jank laptop this year. It wouldn't turn on unless you lifted up the keyboard frame of the laptop and pressed the power button, the charger didn't fit in right, and the specs were very low. However, he was able to do all our programming on it.
So, in the end, I recommend going with a laptop over a netbook.
Follow me twitter dot com slash frc zach
Unread 03-06-2010, 22:06
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
One thing, do not modify the class mate at all, we installed an antivirus, it messed up the whole boot up commands and stuff, we had to reformat and install the OS again... and trust me you never want to go through with it, the processor is too $@#$@#$@#$@# slow
Unread 03-06-2010, 22:09
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
all you need is debian, a shell and the sun JDK+ant
or at the least, wine, an x server and a base busybox install
Unread 04-06-2010, 08:29
Back after 4 years off
FRC #5279
Just curious, have you had issues using USB to serial converters? I have had to program a variety of things that have serial interfaces (PLCs, Controllers for Robot Arms, various micros) but have never had problems using my ThinkPad with a USB to Serial adapter.
Back to the thread topic. As said before any new computer will run the programming software. I would recommend buying something fairly portable (14 or 15 inch screen) with pretty goods battery life. I know that at competition it can some times be difficult to find a place to plug in. Other than that just make sure it is comfortable to type on. Some computers that are designed for entertainment tend to squish the keyboard so they can fit additional controls for media.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Laptop "Dashboard" KRibordy Programming 9 02-04-2009 07:44
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
The "fix-it window"? Jolly good show -or- is 23 cups of coffee/day really excessive? erniep General Forum 17 14-01-2005 12:06
Really good "Rube Goldberg" Rich Wong Chit-Chat 2 23-07-2003 00:33
Good job diffusing "american selectivness" Ben Mitchell CD Forum Support 2 07-05-2002 10:17
