Go to Post It's not about a team having lots of money to spend to travel the world to share FIRST but how the team draws the world into their FIRST experience. - Steve W [more]
Unread 04-06-2010, 19:02
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Chain driven vs Direct drive mechanum
Originally Posted by CalTran View Post
Cons:
Chain is like a woman. High maintenance XD
Seriously?
--Madison--
...down at the Ozdust!
Unread 05-06-2010, 18:31
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Originally Posted by Tom Line View Post
A correctly set-up chain drive should require zero maintenance. We use 25 chain and didn't have a single break or issue, nor did we ever have to adjust it.
The trick is to hand grind (or cnc your chassis) so that you have good alignment.
The other trick is to develop a tensioning system that doesn't add friction, and keeps the chain snug. Snug, not TIGHT. Tight chain is bad. Snug chain with just a hint of play is perfect.
Our 8 wheel traction drive train had more problems with the plaction wheel fasteners working free then breaking off. We were using grade 8 fasteners and locknuts. A bit too much forward and back working I guess.
I wonder if it would be a good idea for andy mark to put 8 more holes on their chain sprockets and 8 nubs on their wheels so the two 'key' together.
the fact that they were grade 8 was probably the problem, hard bolts don't bend, they snap, and aren't very forgiving of shock forces, grade 6 is probably a better option and 8 more holes would weaken the sprocket pretty severely.
i've never heard of a team who have had issues with bolts snapping before, we never have that problem, but then again, we've never used traction drive, only mechanum and a couple tank drives.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 05-06-2010, 21:55
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Grade 6? As far as I know there are grades 2, 5, and 8. Grade 8 bolts are marked with 6 lines though, it's all very logical
Fasteners do very poorly when they're loose, regardless of grade. I would recommend using ny-lock nuts at the very least, and maybe add a split or star lock-washer. It might be an appropriate place to use a smaller fastener with a higher torque so that the fastener does not lose clamping force during operation.
Unread 05-06-2010, 23:00
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We started with grade 2's. The only type of nut we use is nyloc. Those worked for 1 competition, and started breaking and falling onto the field.
We went to grade 8 with nylocs. Those worked for 1 district, State Championships, then started snapping on the Newton field during the finals match.
We've replaced the grade 8's that had broken at Championships and are running that way. I don't expect a problem: we'll check it after the Tardec competition this Monday, after Marc later this month, and then after IRI next month.
However, I think that this may be a larger problem for high-torque drives that are used a lot. The side force from the fasteners simply isn't enough to keep the sprockets from working, and that eventially snaps bolts off or causes them to loosen (nyloc or not).
That's why I'm suggesting some sort of mating system between the sprocket and the hub of the plaction wheel.
Admittedly, our robot got a lot of use this year at 65+ matches plus practice field time. In addition, we had a high amount of skid-steer drag during turning. We went with the longest wheel base that the motors could turn so that it would be difficult for other robots to spin us. It was ALWAYS the bolts in the double-sprocketed wheel that failed first (the rear wheel was chain driven on the inside and had an outside sprocket that drove the next wheel forward). We had one sprocket on the inside and one on the outside and were using laser-cut spacers that were essentially copies of the Andy-Mark ones.
Unread 05-06-2010, 23:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
It sounds as if the bolts are directly transmitting drive-line loads. To the best of my knowledge drive-line fasteners (or any fastener for that matter) does its job best when the clamping force it provides transmits loads through the friction produced from said clamping force. Are the bolts being re-tightened after every match? Are you using a torque wrench to ensure a minimum clamping force or just "TFT" (till it feels tight)?
An FSAE car I worked on used a single lug nut in the middle of the wheel and 6 aluminum studs on the wheel hub. There was no way the aluminum studs could handle braking or engine forces on their own. We did the math and determined that our center-lock lug nuts would need to be torqued to around 110ft-lbs to give enough clamping force to transmit engine and braking torque without relying on the studs, which were there mainly for aligning the wheel. Every time before the car went out, the lugs were all re-torqued, and we never had a problem.
Unread 06-06-2010, 03:29
Tom Line's Avatar
We're definitely not using a torque wrench, but we're also making those bolts pretty tight. (I generally have a good feeling for pretty tight - I work in an engine plant and deal with a lot of bolt torque testing). I'll check on the torque next we tighten them and compare it with the recommended torque for a grade 8 fastener of that size.
The more I think about it the more I think you're right about the fasteners taking all the shear rather than just acting in tensile. Thanks for the suggestion.
Unread 06-06-2010, 09:31
Do you have room to increase the diameter of the standoffs? Stiffer standoff with a bigger footprint would likely reduce the fatigue failure of the bolts.
Unread 06-06-2010, 23:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Let us know how it turns out!
A second thought occurs: is there any abnormal wear around the bolt head or nut clamping area? (I think this is called "fretting") it could be that the bolts are losing tension from part wear.
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
easyC Mechanum Drive Code Kingofl337 Programming 0 12-01-2007 23:48
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 05-06-2005 12:19
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
