Go to Post Safety glasses may be a nice forehead protector, but thats not what they are made for. - Quatitos [more]
Unread 06-06-2010, 01:48
EricH EricH is online now
Re: The Age before AndyMark
I'd actually put the 6WD on 254/60 in 2004. That year saw the first set of twin robots in FRC--the only thing different was the color. (It also saw massive debate on collaboration such that two or more teams built the same robot.) Their joint drivetrain became known as the West Coast drive for some reason. 980 might have had something to do with it by winning IRI, but how much influence they had is unclear.
And as for the '04 KOP pneumatic wheels being poor performers, I think it appropriate to say, "to each his own", and then go use said wheels to climb a 6" step autonomously. (And then, 15 seconds later, have no further need for them...)
Unread 06-06-2010, 08:32
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Going far enough back, before the days of IFI and AndyMark you were required to buy everything from the Small Parts catalog or use what was in the kit. If you wanted to build a special gear box you had to make it from parts that were in the catalog. At the end of the year you had to return your controls, after a while you could buy them for a cost.
The batteries used to be two drill batteries and you also got the two drills. Several teams would use the drill transmissions for their driveline.
Things have come a long way since then.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 06-06-2010, 10:00
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
We started in 2003. I believe 2003 was the first year for a kit chassis. It consisted of 2 2"x4" extruded box aluminum and two aluminum tubes to connect the box aluminum. The transmission was a complex setup with a Bosch drill transmission and motor clamped into a plastic holder which was then connected by way of a hex shaft to a gearbox with one set of helical gears. We used the gearboxes for prototyping, but then went on to use just the drill transmission setup with chain reduction and eventually switched to the "Nothing but Dewalts" transmissions in 2005 after spectacular failures with the Bosch transmissions.
We also used to make our own omni wheels, starting in 2004. The first version used a carbon fiber/AL hub and a UHMW rim and kNex wheels. .2004 was the first year carbon fiber was legal. The design evolved over the years, changing the hub to aluminum and the rollers to hard plastic and then to a rubber material with brass inserts. These were very time consuming to build.
Eric
Unread 06-06-2010, 19:56
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
So...
trying to put the history in the right order I dug back in my memory, dug to some old threads, read some stuff in this thread, and talked to some of the principles:
2002 - first year for the CIM in the kit (remember when the drill motors/trannies were the drivetrain of choice?)
2002-2004 there was a gearbox in the kit - a questionable helical one not too many folks used.
2005 - first "robust" gearbox in the kit - Designed by Paul Copioli, provided/sold by IFI, AndyMark supplied a few gears for this box.
2005 - first FULL kitbot chassis - designed by JVN @ IFI ... a novice/rookie could really build a "whole robot" right out of the box for the first time.
Every year since 2005 there has been a similar gearbox and a kitbot chassis in the FRC KOP. 2007 saw Banebots take over as the kit gearbox (with mixed results). 2008 was the first year AndyMark was the sole supplier of the kit gearbox. 2009 was the first year AndyMark was the sole supplier of the kitbot chassis, IFI was the kit supplier of this item through 2008.
Really, when I think about what's made mobility in FRC so accessible to so many, raising the bar for every team, I think about Paul, JVN, Andy and also Tony Norman and Mark Koors. We all owe a lot to these folks - even the teams who don't use these gearboxes or chassis products. Through their selfless acts and superior design abilities the "weakest" of teams stands a chance to be competitive and the "best" of teams now have all kinds of choices and design options they can pursue.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 07-06-2010, 12:51
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
Originally Posted by Rich Kressly View Post
So...
2002-2004 there was a gearbox in the kit - a questionable helical one not too many folks used...
"Questionable" is being nice. We used these in 2003 and it blew up every other match. Luckily we were able to get all the spares we wanted at events because most of the other teams weren't using them. It was a major accomplishment when our robot managed to get to the top of the ramp...
Unread 08-06-2010, 14:01
Dick Linn's Avatar
no team (Synergy)
I remember using the Bosch drill motors when they came with the cordless drill shell. Our first year, we cut the grip handles off, glued the shells to a 1" x 4" board and held it together with hose clamps. Those drill motors/trannys were hard to mount.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 08-06-2010, 14:27
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
+1, and the couple times FIRST provided plastic mounting brackets they were total garbage. In one competition ours fell apart and the Bosch transmission got really messed up.
Unread 08-06-2010, 17:07
Dick Linn's Avatar
no team (Synergy)
Those plastic mounting brackets were tricky. I used some rubber shims and a bit of voodoo when aligning things to prevent side loads, etc. We also used two bearings on the connecting shaft. It was definitely not a quick bolt-together proposition. Never broke in competition, though.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
pic: AndyMark has the Nano; we have the Shuffle! rob_c Extra Discussion 10 19-01-2010 22:30
Assembly of the AndyMark gearbox in Pro/E? jholland Pro ENGINEER / Creo 6 09-01-2009 17:59
Is AndyMark the new IFI? Manoel General Forum 27 24-09-2008 19:39
Mounting encoders to the AndyMark Joel J Technical Discussion 11 31-01-2007 21:32
From the Ice Age to Robot City. The Few, The Proud, The Machines (new movie) Elgin Clock Televised Robotics 21 14-03-2005 15:14
