Re: CNC Laser
My college recently bought a 60 Watt laser cutter for upwards of $15k, and it could barely cut .250 Delrin or .375 acrylic. Don't even think of being able to cut aluminum, it has a hard enough time just engraving color anodized aluminum. Unless you want to shell out massive amounts of money, most institutional-grade laser cutters are designed for large amounts of prototyping, primarily with acrylic. |
Re: CNC Laser
You really need to decide what the machine's capabilities must be, and then select a design.
Just like building a FRC robot. Once you know what capabilities you need, contact a manufacturer and let THEM help you determine what machine you need to fulfill those requirements. They can also help you make intelligent choices when you need to compromise - once you see the prices, you'll understand what I mean. |
Re: CNC Laser
Any recommended models or manufacturers to look at? Thanks, -RC |
Re: CNC Laser
A quick eBay search found a used one (69,039 hours, or in other words almost eight full years if it ran 24/7/365) for less than $20k, but at 16,660 pounds this isn't something that can be easily moved into a school environment. |
Re: CNC Laser
I am by no means an expert however I believe a laser capable of aluminum in any measurable thickness would be over $100,000 and probably even closer to $150,000. Lasers really don't do well with aluminum even extremely powerful ones with anything thicker than about 1/4"
You could look into a hi-def plasma which would be a great deal cheaper (~50-75k) and still perform well or maybe just forget the idea altogether and get a production mill. While Im thinking about it I bet you could get a smaller waterjet for much less than a laser. Check out Omax machines Last edited by sdcantrell56 : 09-06-2010 at 09:32. |
Re: CNC Laser
Re: CNC Laser
I should add that the vo-tech center at my old HS built a workable CNC plasma cutter (5'x9' IIRC) with a donated torch and power supply for about $4500 including a computer and software. It was a very fun project (I designed and machined the stepper motor transmissions) and the machine still works great 5 years later.
Edit: Found this article from Torchmate: http://www.plasma-cutter.com/comparison.htm it compares plasma, hi-def plasma, and laser. Last edited by JamesCH95 : 09-06-2010 at 12:50. |
#8
Re: CNC Laser
I would look a Hypertherm Powermax45 or Powermax1000, for ~$1600 or ~$2200 respectively. There will be other costs associated with setting each of these machines up on your CNC table, but I do not think you will be able to implement a laser cutter of similar capacity for even close to this amount of money. |
| EMC linux + CNC mill + CNC Lathe | Leav | Technical Discussion | 8 | 09-11-2008 23:08 |
| Intelitek CNC Motion - Virtual CNC Machines | Kingofl337 | Programming | 0 | 19-03-2008 11:29 |
| Laser Rangefinders | DavidGitz | Control System | 14 | 17-05-2007 17:56 |
| 4.3.4.1 - onboard laser? | Ethulin | Rules/Strategy | 29 | 15-01-2006 13:13 |
| To CNC? Or not to CNC? | phrontist | General Forum | 21 | 26-03-2004 13:45 |
